WoodshopTips single PDF download
reubenjames
Post by reubenjames »
Hello all!
I was messing around on the old http://www.woodshoptips.com/tips page recently and found it a bit cumbersome to use. The search doesn't appear to work anymore, and using the dropdown to navigate was also a bit awkard.
The majority of the first 215 tips on there also have accompanying PDF files you can download for free. So I did what any sane techie would do, and I used wget to automatically download all the PDFs on the site, and then I combined them all into a single PDF, then I extracted the article names from the dropdown list on the page, and finally I hand copied/pasted all of those names into the bookmarks in the PDF.
I know a lot of this material can be found elsewhere, and some is straight from PTWFE, but I thought it might be useful for some people. You can use the bookmarks in the PDF to navigate, or you can search the entire PDF itself easily.
The file is ~170 MB, the link is below. I hope this helps someone!
https://dl.dropboxusercontent.com/u/522 ... opTips.pdf
Alec S.
1985 Mark V upgraded to 520 and Power Pro (SN 000527)
1983 Mark V Shop Deputy (SN 163487)
1982 Mark V headstock (SN 122265)
1949 (?) 10 ER in transition to dedicated drill press (SN 18677)
11" Band Saw (Aluminum Table System upgrade) (SN 34026)
4" Jointer (SN 02-18-98)
6" Belt Sander (SN 19012)
18" Jig Saw (SN 17407)
20" Scroll Saw (SN 010593)
12" Thickness Planer (SN 10406)
Strip Sander (SN pending)
DC3300 Dust Collector (SN 102088)
Lodgepole
Re: WoodshopTips single PDF download
Post by Lodgepole »
Thanks! I appreciate the effort you must have put in to this. I definitely plan on using it!
So teach me about 'embedded bookmarks'.
reubenjames
JPG wrote:So teach me about 'embedded bookmarks'.
I assume you are asking about the bookmarks in the combined PDF file? Well, if I were to just download all the PDFs and use Adobe Acrobat to jam them all into a single PDF (which I did), what you would end up with would be each bookmark in the PDF would use the file name. Unfortunately, the file names for these PDFs were all dates (030518.pdf, and so on), so it wasn't every helpful. So I went in and re-named the bookmarks so instead of showing "030518", it would show something like "All you need to know about sawing" or whatever the title in the dropdown menu of their website listed for that article.
A picture is worth a thousand words:
So you can just click on the article you want using the bookmarks on the left and it will jump to it. Or, of course, you can always just search the entire PDF for the term(s) you are looking for and it will find them that way.
Is that what you were looking for?
That'll do RJ, that'll do! :cool: Thanks.
This is going to be handy! I have bunch of these printed and filed in a note book but not all of them. Having the file and all bookmarked will allow local searches.
Thank you.
rjent
Post by rjent »
Downloaded, thanks dude, you da man! :cool:
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
Mike907
Post by Mike907 »
Very much appreciated. Loading on my iPad now.
Thanks again,
pieceseeker
Post by pieceseeker »
Thank You!!!
john_001
Post by john_001 »
Amazing! Thank you.
