Head stock locks
Re: Head stock locks
Tad wrote:and yes they were both seated in what I thought were the correct position as were the old ones
Ahh, but the old ones slipped! ;)
So look at the end of the rod with the wing clamp handle(78) with the clamp 'tightened'. There should be threads remaining('78' NOT bearing against the wedge(51)).
Also you should not be able to move the assembly(50 - 79) in/out when pushing/pulling from the handle(78) end.
If this does not help identify the cause of slipping, we will need pix.
Tad
Post by Tad »
It is doing the very same thing it did with the old locks on it. could there be a problem with the way bars?
Tad
Post by Tad »
It is doing the very same thing it did with the old locks on it. could there be a problem with the way bars? and yes there is thread showing nd I can move it back and fourth.
ERLover
Post by ERLover »
I have not had this problem, I am also not a SS eat and sleep guy like some here that have posted here. I am guessing as some posted here, there is a fine adjustment on the other side to get to a happy medium of locked and not locked in place without slipping, or you do not have wedges internally in there proper position to lock against the tubes.
There is no 'adjustment' on the headstock lock, but both wedges must press equally against the inner sides of the way tubes.
ERLover
Post by ERLover »
JPG wrote:All that is not 'normal.
Have you adjusted the lock stop nut? Located on the backside end of the locking bar.
What, JPG that is what I was talking about, then you posted there is NO adjustment, or are we misinterpreting post.
Tad
Post by Tad »
the problem still exsists
Tad
Post by Tad »
Could the problem be in the way bars?
ERLover
Post by ERLover »
Tad wrote:Could the problem be in the way bars?
I doubt it, unless maybe you sprayed them up with supper slippery Silicone dry lube.
You missed the "WHOOPS". ;)
