What do I have here?
Re: What do I have here?
A sluggish floating sheave will definitely contribute to hard turning of the speed control knob towards slow. Also that would cause excessive pulling of the clip on the button bearing/porkchop when moving towards fast. You cannot over lubricate either movable sheave.
beeg
Post by beeg »
The sawdust will love the oil and grease.
Two things jump out in that pix.
The leaf spring on the porkchop arm appears displaced from being centered on the arm.
The wire loop is not a loop. Also it appears to be coming from the side of the bearing 'button' rather than the top/bottom. Neither does it have the fine 'coil' of it.
Unclemac
Post by Unclemac »
I hadn't noticed that JPG. I went back and found another pic and everything is there, just a bad angle in the first pic I guess. Had me scared for a minute there. :D
porkchop spring.png (1.98 MiB) Viewed 1921 times
