10ER Motor
rpd
Re: 10ER Motor
Post by rpd »
skou wrote:Dan, there is no "speed reducer" for
the Model 10,
however, belts and pulleys WILL achieve
the speeds you want.
The Model 10, is STILL the strongest
Shopsmith built. Period!
steve
I think he meant a Speed Changer. ;)
Dansmith
Re: 10ER Motor
Post by Dansmith »
the Model 10,
steve
Thanks, Steve. Is replacing the pulley as simple as removing a key, and replacing with another pulley? You have just regenerated my interest in the 10ER. I would like to reduce it to about 500 rpm, give or take, and leave the top end speed available.
Re: 10ER Motor
A speed changer will get you a range of 425 to 6800 rpm.
Re: 10ER Motor
JPG wrote:A speed changer will get you a range of 425 to 6800 rpm.
Which is lower and higher than the three speeds (850, 1725 and 3450) of the stock 3 step pulley set. Plus you get everything in between.
Dansmith
Re: 10ER Motor
Post by Dansmith »
A speed changer it is. Thanks.
everettdavis
Re: 10ER Motor
Post by everettdavis »
Here is a variable Speed Mechanism for the 10 series...
Everett
10E - 10ER Variable Speed Changer.png (734.73 KiB) Viewed 7108 times
Sterling
Re: 10ER Motor
Post by Sterling »
skou wrote:
Dansmith wrote:10 ER for sale locally for $200.00. If the old motor goes out on on of these, is the motor bracket such that you could easily bolt-on a new 1 hp motor to it?
Also, how easy is it to replace the quil bearing if necessary?
One more question. Will the lathe tool rest and the tail stock from a MKV 500 fit it?
My brother, Sterling here, has mounted a 1 HP HF
motor on one of his (formerly my) Model 10s.
Yes, the motors mount, mounting base up.
ANY 56 frame motor will fit, except for the
capacitor. My solution, raise the whole
machine. Since the weakest mode of the
Model 10 (or any Shopsmith) is the table saw,
raise the whole rig, and get a decent table saw.
Oh, (and this might upset a few of the "Aluminium"
fans) the Model 10 is the best at lathe and both
versions of drill-press.
And, the model 10 is the WORST to put in vertical
drill-press mode. Something about all that Cast
Iron.
steve
It was a two hp motor. Fit just fine.
Sterling
Sterling
Re: 10ER Motor
Post by Sterling »
the Model 10,
steve
Down, boy. Easy on, there.
Dansmith
Re: 10ER Motor
Post by Dansmith »
Everett, that is one classy looking 10ER.
Dansmith
Re: 10ER Motor
Post by Dansmith »
Thanks, Sterling. 2HP :)
