Aftermarket Fence for 510?
algale
Re: Aftermarket Fence for 510?
Post by algale »
A new 510 extrusion is $63.80 p/n 515328.
If it were me, I'd dissemble, mount an sanding disk and square up the ends (using the miter gauge to hold it steady). It will shorten it a bit at the outfeed end which means the outfeed clamp will be a little more out in space than currently, but I would think not so much that you couldn't adjust the tension. You've got little to lose.
algale
Post by algale »
Nice looking -- drum?
Can we assume you have used these two screws to "square" things? And either can't get it square or it doesn't stay?
JazzLuthier
Post by JazzLuthier »
Yes, it is a snare drum, but I mainly make stringed instruments.
If I trued up the mating surface, then the screws underneath won't pull the extrusion tight. In other words, it will be left loose which is counterproductive.
Yes, I have two screws, but when tightened, they cause the angle and there's not enough room to shim.
JazzLuthier
I could certainly try to true up the the end. The question is, do I sand the aluminum extrusion or on the mating surface on the locking mechanism?
Also, how much play is there when the screws underneath or reattached? Are they self centering? It seems like I had no adjustment when I messed with them.
rpd
Post by rpd »
JazzLuthier wrote:I could certainly try to true up the the end. The question is, do I sand the aluminum extrusion or on the mating surface on the locking mechanism?
This is a really good video on aligning the 510 fence and problems you might have.
[youtube]https://www.youtube.com/watch?v=09gXRyN1K4s[/youtube]
JazzLuthier
Thank you. I've seen this before, but I will review again.
ianw
Post by ianw »
Ryobi BT3000 or BT3100 rail and fence will work with 510. But you need to buy some special mounting hardware that is designed by one of member. chech this post. https://www.shopsmith.com/ss_forum/wood ... t9280.html
Sent from my iPhone using Tapatalk Pro
SS520(upgraded from 1986 SS510), Band Saw, Belt Sander, Jointer, Biscuit Joiner, Speed Reducer, Scroll Saw on Power Station
SS500 with 610 Jig Saw (awaiting restoration)
ianw
Post by ianw »
check the ebay link from this post, http://www.shopsmith.com/ss_forum/viewtopic.php?t=13672. You can ask the seller if he still sells the kit or the mounting hardware.
algale
Post by algale »
Nice work! Even though I don't build drums, your method of making these perfect looking cylinders would be interesting to see. You should do a photo spread on one.
