Broken Tool Rest, Need Replacement
Skizzity
Re: RE: Re: Broken Tool Rest, Need Replacement
Post by Skizzity »
devyn59 wrote:I have a related problem with the tool rest that came standard with the Mark 7. Have only started turning in the last two months, so not really heavy usage to this point. I was repositioning the tool rest the other day and one of the plastic handles broke off. Wasn't applying much pressure so I assume it was defective. I can still use the rest, but am having to use a pair of pliers to loosen and tighten the rest into position. I have contacted ShopSmith twice by email but no response. Does anyone know if there is a replacement part for the handle and also if there are suggestions on getting more functional rest. This one seems pretty limited.
http://www.shopsmith.com/ownersite/item ... tem=521689
And
http://www.shopsmith.com/ownersite/item ... tem=521688
Does the 5/32" Allen wrench not fit in the set screw?
rpd
Post by rpd »
You should be able to loosen/tighten the screw with an Alan key.
Those handles are and upgrade. http://www.shopsmith.com/ownersite/cata ... pgrade.htm
MKC tools also has replacement handles that are made of metal, and at a better price. http://mkctools.com/mkvtoolresthandles.htm
Shopsmith also sells the Universal Tool Rest, which is more versatile. http://www.shopsmith.com/ownersite/cata ... olrest.htm
