Finished Bench for Son-in-Law
ARCretired
Re: Finished Bench for Son-in-Law
Post by ARCretired »
Just a extra comment. The drawing "Size" and "Shape" does not change as you revise calculations, but the displayed dimensions do change. As long as you are not radically changing the design, that has been OK. If you are completely rethinking the concept, then probably good to redraw to represent the new concept. I've done that a number of times, when I am just dissatisfied with something, and decide to start over.
That is one of the most clever (and unorthodox) uses of Excel that I’ve ever seen! I use it for similar calculations all the time, but it never dawned on me that one could use it as electronic graph paper. :cool:
ARCretired
Final Pictures with removable outboard supports for miter saw. Bolts slide into dog clamp holes. Lock nuts for height adjustment.
Miter Saw Supports.jpg (27.88 KiB) Viewed 4338 times
Height adjustment w' carriage bolts
Miter Saw Support Detail.jpg (31.17 KiB) Viewed 4338 times
newportcycle
Post by newportcycle »
Excellent job, makes me wish I was born clever instead of handsome.
