Day breaks yet to come but I have been in the shop to try this out.
I cannot say that it was successive but for reasons that disappointed me immensely. My Mark V is in great need of being serviced. With all of the packing and downsizing that has been going on here, routine maintenance has been ignored for months.
My main table does not move up and down easily with nothing attached to it. The carriage and the table support tubes need to be cleaned and waxed; as do the support tubes on the extension table. I got my first hint of failure when I attempted to relocate the extension table. I could barely move it up and down by hand. There was no way it would move as an attachment to the main table. A little wax would do wonders, I am sure.
Then, moving over to the main table and carriage, I found the same thing. I can raise and lower the main table but to go up I need both hands on the table height wheel. That is not the way it should be. By itself, the main table/carriage should be height adjustable with ease.
What I just experienced is most probably easily correctable. Just dig out some clean rags and a can of wax. Wax, wax...where is my can of Johnson Wax. No where to be found because it is packed in a box waiting for the move.
Though this exercise was a complete bust for me, I did see one thing happening that I hope you will check for your own safety. With the tables tied together, when I attempted to raise the tables the drag tended to hold down the right edge of the main table (pulling it out of square with the blade). This may not be the case with a properly maintained Mark V. Just take heed if you do this in the real world.
If I can get to an Ace Hardware, I'll buy another can of wax and redo this exercise. I really should not put the equipment in storage needing maintenance anyhow. It will only come out of storage in worse condition. ..... I'll need a can of oil too!
