Lighter replacement for main table for horizontal boring
Re: Lighter replacement for main table for horizontal boring
After rethinking what is being discussed here, I doubt that there is a way to accomplish your objectives.
" I want to be able to quickly replace the lathe tool rest with an extension table so that I can clamp the work I am drilling onto the extension table and drill it.
The main table is too cumbersome to make this change quickly, that's why I want to use one of the lightweight extension tables instead".
The proposed solutions, especially mine, require that the Main Table be removed. This is no longer done easily. Over the last three or four years that table assembly has gained as much weight as I have.
ChrisNeilan
Post by ChrisNeilan »
Eric, what table setup do you have? 10er, 500 or 520?
Chris Neilan
ryanbp01
Post by ryanbp01 »
Here's an idea: what about replacing the straight tubes of the extension tables with toothed tubes for the main table? I think that would give you greater range of motion. EBay might be a good source.
ryanbp01 wrote:Here's an idea: what about replacing the straight tubes of the extension tables with toothed tubes for the main table? I think that would give you greater range of motion. EBay might be a good source.
If memory serves me well, the tubes on the extension tables are spaced closer together than those on the main table.
epodietz
Post by epodietz »
I have a 500 table and 3 extension tables.
The tubes on the main table are spaced differently than on the table extensions. I would love to be able to use one of the extension tables for this purpose b/c it give me ability to clamp the table saw guide onto the extension table guide rails and use it to backstop the piece I am drilling.
Am now aiming to use the lathe tool rest or lathe duplicator posts w/some kind of adapter onto plywood+masonite and/or extension table. Part #'s p/n 514697 Lathe Duplicator Table Support and 514416 Tool Rest Post. (Thanks for that algale)
When I get all this together and give it a run through I'll post a picture, assuming I have some degree of success.
Two tool rest posts/arms with a connecting flat top including a back stop should get this done.
Another possibility with this erector set woodworking tool.
epodietz
Post by epodietz »
I just bought a second tool rest post (along w/arm & tool rest) from ebay and much to my surprise it is shorter than the post I had. They don't dance well together, for my purposes at least. Anyone happen to know when or why they changed? I am wondering if I come across a third tool rest if it is likely to be different than these two...
Shopsmith tool rest posts.
Shopsmith lathe tool rest posts-lorez.jpg (152.07 KiB) Viewed 11763 times
