Introducing ER#38615
Re: Introducing ER#38615
The original Model 10 manuals said use a light coat of oil on the moving parts but later Magna the makers of Shopsmiths found out that paste wax provided good lubrication without being sticky like oil. Below is a PDF I made to replace the manual information on using oil.
Waxing Supplement Model 10s.pdf
(226.53 KiB) Downloaded 1134 times
All the bare metal parts can benefit from being waxed. It will help protect against rust. I even wax the shafts of the motor and drive sleeves to allow the pulleys to move in and out easier to realign the pulley combinations for the additional 4 speeds the Model 10's can run. Below is a PDF I made showing those speeds.
Table of Speeds Model 10s.pdf
(182.91 KiB) Downloaded 1129 times
If you have a speed changer you will not need the above chart.
