Accessory Shelf Template
fixit
Post by fixit »
Hi hoagie,
I've been using the wire shelf for quite a while now and I'm happy with it. It's true the shelf doesn't collect sawdust; however, the things you place on the shelf do.
It's not a significant problem but don't think this addition will completely solve your sawdust problem - it won't.:(
Leonard
La Vernia, TX
Wood Goods - Custom Woodwork
hardway
Post by hardway »
The current overstock sell has this as the very last item on the list. Anyone know what it looks like?
Item Number 515923
515923 Accessory Shelf Plans
Price $1.88 Sale Price $1.13
Status: Quantity is low.
Tom
Masontown, WV
jb41339
Post by jb41339 »
psf513 wrote:Just a slightly different approach to consider. I used an old white vinyl coated wire shelving section that was laying around the house. I cut it to size and mounted it. The nice part is that it holds eveything you need except sawdust and woodturning shavings. I find that a MAJOR bonus. I can take a picture if desired.
Please do.
Thanks
Jim in Arizona
Jim;
Do you have a map (a layout diagram) that details what each hole in the accessory shelf is for. Some are obvious but others ......?
I want to try to make one of these for myself.
knottythumbs
New Improved Accessory Shelf
Post by knottythumbs »
Any news on the "New Improved Accessory Shelf" and the FREE PLANS?
Knottythumbs
knottythumbs
Accessory shelf
james.miller wrote:When I upgraded to the 520 I built a fence holder to go on the 510 Accessory Shelf. When I bought the new Accessory Shelf a year ago I put my fence holder on it because it holds the fence securely.
The fence holder on the old Accessory Shelf.
[ATTACH]2084[/ATTACH]
Hi James, WOW, the answer to my days of searching: SS tool storage. So, did you say you liked the new or old better? got a template so I can make one?
Knottythumbs
knottythumbs
I'd like to see a picture
Knottythumbs
james.miller
Post by james.miller »
A picture of the old (510) accessory shelf with the 520 fence holder on it with the new accessory holder below it, I put the fence holder on the new shelf because it holds the fence better. [ATTACH]2523[/ATTACH]
520 & Convert.jpg (54.21 KiB) Viewed 9849 times
Jim in Tucson
heathicus
Post by heathicus »
[quote="dusty"]Jim]
I just saw the Accessory Shelf "manual" on the Shopsmith main web site. It has pictures of the shelf loaded with the various components. I recalled this question so thought I would post the link.
http://www.shopsmith.com/ownersite/prod ... yShelf.pdf
Heath
Central Louisiana
rdubbs
Post by rdubbs »
There's a hole that does not seem to be used in with any model that I have put to use, and I've made a small modification that helps me out.
I use the hole to store a crevice tool to use with the DC3300. I also drilled several small holes to hold the Allen wrenches that some of the SPTs require.
The picture is from the manual.
Rick Dubbs
2004 520 w/bandsaw, jointer, belt sander, DC 3300, Universal Lathe Tool Rest, Talon chuck, & Lathe Duplicator
