Mk 5 ER?
Re: Mk 5 ER?
sryoder wrote:Hey! FWIW, I just realized that I don't even need the lower tubes if I do a "Deputy-style" conversion.
I would include them regardless.
Re: Mk 5 ER?
Bench tubes and a bench? What’s your thinking?
larryhrockisland
Re: Mk 5 ER?
Post by larryhrockisland »
Look at this post from 2017, https://www.shopsmith.com/ss_forum/view ... 15#p240715. I checked the link to the Wayback site and the pictures still come up today. I didn't ever try to use any of the ideas although I did add spacers to one of my 10ERs to raise the lathe height. https://www.shopsmith.com/ss_forum/view ... 05#p258905
Cheers!
Larry Hargrove
Rock Island, Ok
1957 Mark V 500 (350389)
1953 10ER
Another 10ER
Bandsaw 2012 Jointer 2012
everettdavis
Re: Mk 5 ER?
Post by everettdavis »
Yes, yet the lower tubes add some rigidity plus, allows you to drop some U-Bolts across the lower tube through the wood base to strengthen it.
If you do turnings you may really like having the weight of the base secure the platform so that it does not walk across the floor or becomes misaligned.
Workbench retractable casters can make it very easy to move when the base is loaded with other tools and accessories.
Everett
sryoder
Re: Mk 5 ER?
Post by sryoder »
larryhrockisland wrote:Look at this post from 2017, https://www.shopsmith.com/ss_forum/view ... 15#p240715. I checked the link to the Wayback site and the pictures still come up today. I didn't ever try to use any of the ideas although I did add spacers to one of my 10ERs to raise the lathe height. https://www.shopsmith.com/ss_forum/view ... 05#p258905
Thanks Larry. That link was very helpful. Nice to know that someone else has trod this path before me.
-Steve
-Steve Yoder, Mark V Model 500
sryoder
Re: Mk 5 ER?
Post by sryoder »
This is all great feedback folks. Keep it coming.
rpd
Re: Mk 5 ER?
Post by rpd »
This is an older thread, The post linked is by the late - great Bill Mayo, but check out the rest of the thread too.
https://www.shopsmith.com/ss_forum/view ... 051#p45051
sryoder
Re: Mk 5 ER?
Post by sryoder »
rpd wrote:This is an older thread, The post linked is by the late - great Bill Mayo, but check out the rest of the thread too.
Thanks. This discussion looks like it pretty much covers most of the things I'm wondering about. Now all I have to do is get started on the project.
rpd
Re: Mk 5 ER?
Post by rpd »
You can make brackets to mount the MkV castors on vertical legs. I would mount them out board of the legs or cabinet sides.
https://www.shopsmith.com/ss_forum/view ... 94#p152494
Re: Mk 5 ER?
Steve,
A simple stand possibility would be a bottom frame with lockable casters and two box ends on top, at the height needed for you, to hold the Headrest and Base/Arm ends. Keep the bench tubes for upper frame support. You can use small "L" brackets to attach the Base and Headrest to the stand ends. This would keep all parts of the Shopsmith original for later restoration. The box ends can have holes drilled into them to match the spots where the extension table posts go. Another option would be to just use two box ends with lockable casters to replace the bench legs without a base frame. My thought was having the two boxes attached at the bottom would be more stable but it could function without it just like the Shopsmith legs do.
Just an idea that came to mind while reading your post and other suggestions.
