jointer
whwilton
Jointer
Post by whwilton »
Thanks for the helpful responses. I am in the finishing phase of this job now but I will try packing the jointer in a few days.
The temp. has been in the teens for days with no end in sight and I am having a hell of a job keeping my shop warm.
Thanks again for the help, Bill
Ron309753
Post by Ron309753 »
jpg40504,
You can add a Jointer Dust Chute Retro-fit Kit (part # 555077) to your jointer. It's on sale right now for $29.09. Without the dust chute the chips should fall straight down under the cutter head. With the dust chute the chips should fly out to the left through the chute. You can hook up a dust collection unit or a shopvac to the chute.
Ron309753
beeg
Post by beeg »
Ron
Your key word is SHOULD. I have the dust chute installed and the chips fly out from under the infeed table. :eek:
whwilton
Post by whwilton »
This is the part that does not work.
jointer chip chute
Hello!! The part that is not working is the "CHUTE". I do NOT have a problem with chips squirting out from under the infeed table. I do NOT have a chute at all.
Think about the task at hand.
The cutter head slices off a small piece wood of and forces it towards the infeed table!
The chute attempts to alter the direction the chips are traveling.
IFF sufficient air flow exists through the chute a "vacuum" system will assist this alteration of direction.
This air flow MUST come from the proper path.
I assume most of the air flow is down past the cutter head from above.
MAYBE you need some air flow from the infeed side????
Just some thoughtful rambling by someone who does NOT have your problem!;)
