Gilmer Drive System - Cleaning, inspecting, testing
jpalmer59 wrote:DO you know where I can order a replacment berring. The one I have has a dammage metal cover on one bering. It looks like some one attempte to remove it by banging on a screw drive. It turns but I am afraid it will not last.
You need a 25mm(id) x 52mm(od) x 15mm(wide) bearing It should be double shielded(metal cover both sides).
I have purchased bearings from these folks - reasonable prices/shipping and quick response. There are others.
http://www.vxb.com/page/bearings/PROD/Kit7124
If you replace one, you oughta replace both.
However you will need a bearing puller/press to remove/install new ones.
IMHO, If you are not experiencing any problems(other than it looks damaged), I would defer until is exhibits actual operational problems.
beeg
Post by beeg »
JPG40504 wrote: IMHO, If you are not experiencing any problems(other than it looks damaged), I would defer until is exhibits actual operational problems.
But I'd order one now, just to make sure the originals never need to be replaced. :rolleyes:
dcdak16
Post by dcdak16 »
I have an older Mark V with a Gilmer drive, but it does not have any cluch mechanism what so ever. The cogged portion is part of the shaft.
Stitch
Post by Stitch »
Does this mean there are two or more versions of the Gilmer system.
Is there more than one polyv system?
jcraigie
Post by jcraigie »
There are indeed two gilmer drive versions, one with the clutch and the very early greenies had no clutch.
1984 Mark V 500 and an early 1954 greenie. jointer, belt sander, bandsaw, jigsaw, planner.
Jeff
Stitch
Post by Stitch »
jcraigie wrote:There are indeed two gilmer drive versions, one with the clutch and the very early greenies had no clutch.
If you never experience any sudden stop does the clutch offer a useful function. I guess what I am really asking is if I have a clutchless gilmer should I upgrade.
Ron309753
Post by Ron309753 »
I used these on my greenie's drive sleeve (I selected metal shields):
http://www.usabearingsandbelts.com/18.h ... zzy_sku]=1
Sincerely,
Ron309753
Ron309753 wrote:I used these on my greenie's drive sleeve (I selected metal shields):
http://www.usabearingsandbelts.com/18.html?m7:search[keyword]=6205-2RS]=phrase;search[matchWholeWords]=0;search[keywordFields]=text0:text2:text3:string0:code;search[nested]=1;search[group]=735037;search[fuzzy_sku]=1
Sincerely,
Ron309753
So that I might find this thread when I do a search on " bearing ".
billmayo
Gilmer Clutch
Post by billmayo »
Stitch wrote:If you never experience any sudden stop does the clutch offer a useful function. I guess what I am really asking is if I have a clutchless gilmer should I upgrade.
The Gilmer clutch should save the Gilmer belt if the quill stops suddenly. However, I find most Gilmer clutches are either frozen or slipping, so not sure an upgrade to a clutch would be worth while these days. I rebuild, test and have available the Gilmer clutches with or without new bearings. There are an additional Gilmer belt supplier so the belts are not a future supply problem.
SDSSmith
Post by SDSSmith »
billmayo wrote:The Gilmer clutch should save the Gilmer belt if the quill stops suddenly. However, I find most Gilmer clutches are either frozen or slipping, so not sure an upgrade to a clutch would be worth while these days. I rebuild, test and have available the Gilmer clutches with or without new bearings. There are an additional Gilmer belt supplier so the belts are not a future supply problem.
Who else supplies the correct size Gilmer belt?
Rob in San Diego
