What does the "Carriage Stop Ring" stop?
mickyd
Post by mickyd »
JPG40504 wrote:Where pray tell does one get ODORLESS Mineral Spirits? It IS a petroleum distillate after all!
You just put on the nose plugs that are taped to the bottom of the can....they works get. They guarantee you won't smell a thing.
Home Depot and Lowe's both carry it. It is misleading advertising. It's odor reduced as compared to regular mineral spirits but to call it odorless is a stretch.
Sunny San Diego
mickyd wrote:You just put on the nose plugs that are taped to the bottom of the can....they works get. They guarantee you won't smell a thing.
Think I'll stick with Vick's Vaporub(works for the coroner!).:D
ksdaddio
Post by ksdaddio »
I can still remember the first time this happened to me. It sent shivers up my spine, just like the sound of a childs head hitting the floor after a bad fall. Fortunately nothing broke except my pride for being so stupid. I was lucky that I didn't have a vital body part in the way, or it could have caused a serious injury.
ksdaddio wrote:I can still remember the first time this happened to me. It sent shivers up my spine, just like the sound of a childs head hitting the floor after a bad fall. Fortunately nothing broke except my pride for being so stupid. I was lucky that I didn't have a vital body part in the way, or it could have caused a serious injury.
After doing this a couple times without having a catastrophe, I have sort of learned BUT
the introduction of the lift assist sort of increases the potential for damage. Without the lift assist, one must exert more effort to lift the headstock to the vertical position. With a lift assist installed, the effort to go vertical is much less and can even happen without human intervention if the headstock is to the right of center on the way tubes.
POINT: There is no rubber "Carriage Stop Ring" on that side of the carriage or headstock. Is there suppose to be one?
Maybe I am reading this entire thread completely wrong!
I am sorry but I don't understand. What happened that was so shocking?:confused:
mickyd
Post by mickyd »
dusty wrote:I am sorry but I don't understand. What happened that was so shocking?:confused:
I think he's talking about my post #5
http://www.shopsmith.net/forums/showpos ... ostcount=5
Sunny San Diego
mickyd wrote:I think he's talking about my post #5
https://forum.shopsmith.com/viewtopic.php?p=33040&postcount=5
OK, I see the damage but I have a hard time invisioning that piece being broken out as a result of either the carriage slamming against the base assembly or the headstock slamming against the carriage.
The impact would all be absorbed by the metal immediately around the tubes rather than out in the middle as seen in the photo. Unless, of course, there is something to this picture that I don't see.
Example: we have had some discussion about using a small bottle jack to position the carriage when in the vertical mode. I can see this sort of damage from that sort of pressure being applied to the side wall of the carriage.
mickyd
Post by mickyd »
dusty wrote:OK, I see the damage but I have a hard time envisioning that piece being broken out as a result of either the carriage slamming against the base assembly or the headstock slamming against the carriage.
If you not thoroughly familiar with the "Greenie", I can see how you would have a hard time envisioning how the damage occurred. Here's couple pics that should help you. Notice in the 2D view of the carriage that it has an adjustable. I believe the design intent of this is to allow you to get the carriage up to the headstock at a predetermined limit. If you have to later move the carriage, you can reposition it exactly where it was previously. With the set screw OUT, it actually comes in contact with the headstock. The piece that is broken off has the set screw. If the table is off the machine when you place it in the vertical position, and the head drops.......guess where the first contact point is. Pressure = Force / Area takes it from there.:(
Your envisionment more gooder now?
[ATTACH]3550[/ATTACH]
[ATTACH]3548[/ATTACH]
Sunny San Diego
mickyd wrote:If you not thoroughly familiar with the "Greenie", I can see how you would have a hard time envisioning how the damage occurred. Here's couple pics that should help you. Notice in the 2D view of the carriage that it has an adjustable. I believe the design intent of this is to allow you to get the carriage up to the headstock at a predetermined limit. If you have to later move the carriage, you can reposition it exactly where it was previously. With the set screw OUT, it actually comes in contact with the headstock. The piece that is broken off has the set screw. If the table is off the machine when you place it in the vertical position, and the head drops.......guess where the first contact point is. Pressure = Force / Area takes it from there.:(
Yup, I can see it now. All of the impact force is applied to the set screw and transferred directly to the casting that is the carriage. Thank you for your explanation. I have used a greenie but not enough to be well aware of issues such as this.
I think I would eliminate the set screw and utilize something similar to the carriage stop ring even if I had to devise one of the correct dimension.
I assume the standard carriage stop ring doesn't do the trick or all of you guys with greenie's and goldie's would have already installed them.
dusty wrote:. . . .
Goldies got the RING!:) :) :) :)
