New to me belt sander and stand
Re: New to me belt sander and stand
The Jointer will work fine on the Power Stand. Just use the correct pulley combination to get the actual correct speed. Remember the speed setting used for it on the Mark V (and other Marks) is slower than the actual speed it is running at on the lower Idler's shaft than the speed is for the upper Drive Sleeve Assembly's shaft.
larryhrockisland
Post by larryhrockisland »
I ordered a new drive sleeve for the belt sander and it came in the mail today. The original sleeve was missing so I don’t know what it should look like but the replacement appears to be a piece of bicycle inner tube. Does it need adhesive?
Larry Hargrove
Rock Island, Ok
1957 Mark V 500 (350389)
1953 10ER
Another 10ER
Bandsaw 2012 Jointer 2012
rpd
Post by rpd »
Can't find the reference posts, but if I recall correctly people have recommended. Blow compressed air under the edge of the sleeve while pulling onto the drum. Roll one side back over the other, apply glue and roll back, repeat on the other side.
larryhrockisland
Thanks
Larry Hargrove
Rock Island, Ok
1953 10ER
Another 10ER
