joto wrote:I have no info on setting up the scroll saw. Could u tell me
how it's mounted onto the shopsmith. I think it has to be in
the drill mode - what hold's it down ??
WHERE does he say anything about color?
SS 500(09/1980), DC3300, jointer, bandsaw, belt sander, Strip Sander, drum sanders,molder, dado, biscuit joiner, universal lathe tool rest, Oneway talon chuck, router bits & chucks and a De Walt 735 planer,a #5,#6, block planes. ALL in a 100 square foot shop. .
The original question was sorta "Is there more than one version of Shopsmith scroll saw".
I guess the answer is yes. There are teal scroll saws and there are gray scroll saws. The gray, naturally, are the older scroll saws. This makes the teal scrolls saws (some people call them green while others others call them blue) are the newer scroll saws.
In reality, each of these two models (gray and green) can be purchased as either self driven (standalone) or Mark V driven (not standalone).
I guess then that one could say there are really at least four models.
Example: I have a gray, self driven standalone model that has been modified to include the "quick disconnect, easily retensioned saw blade".
Maybe some people think that means I have had two different scroll saws but they both had the same part number and both were gray and both were self standing - so I think not. I have only had one scroll saw.
"Making Sawdust Safely" Dusty
dusty wrote:The original question was sorta "Is there more than one version of Shopsmith scroll saw".
Good complete reply!
Yes 'teal' is a greenish blue' Quite descriptive name huh! Only a distaff partner would consider that label adequately descriptive. Close relative to mauve and chartreuse in that regard!:rolleyes: (IMHO teal is more blue than green) Now aquamarine is greener!:D
As Bill pointed out, Linda will get you the right parts for the 'version' you have. IIUC, only the colors, table(without/with blade gauge), rear trunion, blade tension and blade mount have gone through design transitions.
