Can't find the serial number
If I read the original post correctly, he's asking about a Mark 5 he received as a result of getting the 10ER.wa2crk wrote:Stitch
If it is a 1947 as you stated your machine should be a model 10E or 10ER.
The serial number would be on the SS logo plate located on the front of the machine. If the logo plate is missing then so is the Ser Num.
Heath
Central Louisiana
Central Louisiana
No! But it would help narrow the age guessing. And then there is the remote possibility he is not looking in the right place, or not recognizing it!BigSky wrote:JPG40504 wrote:In other words:
[/QUOTEumber]If there is no serial number having pictures will not answer the question. All you will be able to do is confirm that it is a vintage shopsmith with no apparent serial number. JPG, maybe you could post a picture to show where the serial number is not shown.
Annnd then there is the possibility to provide information that he did not know was relevant nor how to ask for.
Sure if the plate is not there, only the shadow knows! But there are other items to pursue. Keep a broader horizon! You will be amazed at what a narrow one misses! There is a reason tunnel vision is not recommended for one driving a vehicle!
Have I broadened the discussion enough!;)
That's the way I read it! It may be either a Mark 5 or a Mark V and maybe a VII!heathicus wrote:If I read the original post correctly, he's asking about a Mark 5 he received as a result of getting the 10ER.
Pic sure would help 'identify' it even without a SN!
judaspre1982
Here are my pictures. If the cover on the end of the Mark V is where the serial number is, it's most likely gone forever. Does anyone know what the far left slot is supposed to be used for on this type table? [ATTACH]10294[/ATTACH]
[ATTACH]10295[/ATTACH]
[ATTACH]10296[/ATTACH]
- Pair of Shopsmiths Side by Side.JPG (81.08 KiB) Viewed 5841 times
- Newer Shopsmith Mark V table .JPG (63.64 KiB) Viewed 5577 times
- My newer shopsmith Mark V.JPG (61.14 KiB) Viewed 5882 times
judaspre1982
My guess would be early SS Inc. Wrinkle paint, slender red handles, counter sunk end castings/leg mounting screws. The 'extra' slot is also of that vintage. 1972 - 1984
