speed dial question
billmayo wrote:
mickyd wrote:
The worm gear rides up on the side pf the quadrant teeth and will bend the worm gear shaft when forced to do this action. Otherwise the Speed Control handle set screw will badly scored the worm gear shaft if the worm gear is jammed on the top of the quadrant teeth. The only time this occurs is when the quadrant teeth have been badly worn on one side or broken on that side. This also bends the leg on the backet holding the quadrant allowing the quadrant teeth to wear on the outer edge.
I have been replacing the quadrant roll pin with a #10-32 X 2 1/2" allen head bolt, 2 star washers and a thin Nylock nut after straightening the bracket legs. I have a computer file and pictures plus these parts (free) for this change if anyone is interested. I have been doing this change for around 6 years and over 75 Speed Control Assemblies without any returns or futher quadrant damage at this time.
I have a lengthly soapbox discussion available as to why this occurs but I find just fixing the problem is quicker and my opinion is best saved for another day and subject.
1) The roll pin ALLOWS the leg bracket to bend.
2) Turning the dial too fast towards slow(or the floating sheave[motor shaft] is sluggish due to crud buildup) will put stress on the leg.
3) Turning the dial too far towards slow.
The leg bending causes the worm gear to become mispositioned off the center of the quadrant gear. This causes abnormal wear because the teeth do not mesh properly. This in turn increases the torque required to turn the dial. All that is a downward spiral to needing a new speed control(or Bill's fix).
That be my HO!:)
And YES your 'fix' does wonders for correcting all the problems above(except the cruddy motor shaft).
chas410
Post by chas410 »
[quote="terrell0214"]I am new to ss. when I turn my speed dial after I turn the machine on the speed indicator plate does not turn with the dial. does it suppose to or not. if it should turn how do i fix it?
Could the problem be the spring behind the speed indicator plate is gone or broken? If the above posts don't solve the problem that's where I'd look next.
Chas
chas410 wrote:
terrell0214 wrote:I am new to ss. when I turn my speed dial after I turn the machine on the speed indicator plate does not turn with the dial. does it suppose to or not. if it should turn how do i fix it?
Chas
Yes, Chas, as stated earlier in this thread the dial should change. You have not said but I assume the speed changes even though the dial does not move.
I doubt that the spring has anything to do with this. I suspect it is a simple fix. Review this Sawdust Session and if you are not up and running with an operational speed control dial - re-post your question and we'll see why.
mickyd
Post by mickyd »
What's happnin' with the quotes in the thread????????
Sunny San Diego
mickyd wrote:What's happnin' with the quotes in the thread????????
I don't know. But it seems to be working now.
