It would be prudent to check on its 'progress' and determine possible ship date. If it be back ordered, pm me with yer snail mail address. I will loan you one till it arrives.gkatzz wrote:JPG,
Thank you VERY much for including the link to the part! I can't reach customer service--must be closed for the holiday. At least I can get an order in for a replacement.
Gary
Spindle Assembly not spinning
One came with a 2 bearing quill upgrade. My 1963 vintage did not need replacement! No I do not believe keeping one on hand is necessary.gkatzz wrote:You keep an extra one on hand? Is that necessary? My only worry is that they won't be open for another week!!!!!
If it's backordered, I will definitely take you up on the offer.
Gary
IIRC, the inside of the greenie drive shaft is splined to receive the splined spindle. When it warms up this weekend I'll check to make sure. I thought all ShopSmiths had splined drive shafts. Shows what I know!JPG40504 wrote:Are you saying the inside if the drive shaft is splined? If so, one more difference between the gilmer and the poly-v.
Sincerely,
Ron309753
I don't know for sure but this thread may shed some light on the problem.
Just some additional thoughts.
JPG my coupler is almost 30 years old and no problems although I do have two spares. Both came with two bearing quill upgrades so if he needs one I can spare one.
If the quill shaft is bent AND the positioning washer is missing would a bad front bearing combine to cause enough "whip" and strain to cause a failure??
Wouldn't think so but this is a rare failure.
Ya might need a bearing!gkatzz wrote:Yes. I definitely tested the spindle and spun it in the quill housing to feel the bearings. There's a knocking at each full rotation and the spindle had a slight slap/sloppiness, too. I ordered a new spindle and the coupler---so I'll probably have an extra coupler when I'm finished.
Gary
