Mark VII Cam speed control
robinson46176
Post by robinson46176 »
We have discussed many things about this but I am not all that great at finding the old stuff.
Have these units been tipped to drill press mode and lubed and left sitting like that overnight to get oil in the yoke bearing? I have never noticed mine getting all that hot but then I don't run it a lot so I just can't say. Has anybody felt around to see where it burns your fingers the most? :)
There are several possibilities for operating the speed control without using the rotating cam. One is to use a lever/bellcrank system. A locking T handled control like used on such things as dump truck hydraulic systems could also be used.
One concept that I like is making a wedge shaped cam instead of the round one and using a threaded rod to push it forward or pull it back. Basically it would be a lot like taking the round cam and just straightening it out. One would very easy to machine with simple equipment.
The whole cam concept is pretty simple and there is a long history of such controls on all kinds of equipment. The variable speed drives of a self propelled combine normally use a small hydraulic cylinder to push / pull the movable sheaves. Some of the real old ones used a long threaded rod with a crank on the end sticking up through the cab floor someplace.
hdoilcan
Post by hdoilcan »
If anyone's interested in an aluminum cam, please pm me.
gpartin
UPDATE on Speed Cam
Post by gpartin »
The Process has begun, bigger, thicker where it counts
" That ain't going nowhere "
gpartin
new beefier Cam Speed Control
Post by gpartin »
in the works...just an update
Shopsmith 0012.jpg (146.02 KiB) Viewed 4001 times
Shopsmith 0021.jpg (121.16 KiB) Viewed 3995 times
briallpro
Post by briallpro »
gpartin wrote:in the works...just an update
Please keep me in mind when you have these made.
thanks,
Brian Dubin briallpro@gmail.com
chucks
Post by chucks »
hdoilcan wrote:If anyone's interested in an aluminum cam, please pm me.
Thank you sir...my Mark VII will continue it's long life for sometime to come...now if I can only find a replacement for the rack:D
Chucks in Phoenix Mark V(5), Mark VII(2),Power Pro, Planer, Crafter Station, Jointer,Bandsaw(3),Lathe Duplicator,Belt Sander,Jig Saw,DC3300(2),"Sears Router Crafter", Post Drill, Stand alone Overarm Router. Jointmatic ++++,
wiredone
Post by wiredone »
So, I'll be the devils advocate here....(it's what I do),
Why go to the trouble to make them out of plastic, when a forum member here has already improved the originals by making them out of aluminum instead of plastic... which were famous for breaking. Honestly, if I were to restore or repair a MARK 7, I would definitely opt for the aluminum over the plastic.
I'm not trying to stir anything up, but just trying to understand.
www.wirewerkes.com
Hiding in a Joshua Tree.
damagi
Post by damagi »
chucks wrote:Thank you sir...my Mark VII will continue it's long life for sometime to come...now if I can only find a replacement for the rack:D
I have a mark VII with an intact rack that I am parting out. contact me offline and we can work something out.
damagi AT gmail DOT com
chucks
Post by chucks »
damagi wrote:I have a mark VII with an intact rack that I am parting out. contact me offline and we can work something out.
Actually, I have a backup already.....what I'm looking for is something like the Cam...Steel, Aluminum or New. I know there are a lot available, even places to special order if required, but finding the best place to acquire? I'm looking.
wiredone wrote:So, I'll be the devils advocate here....(it's what I do),
Devil's advocate II here!]it[/B] melts, there are many other parts that will already be melted scrap by then), that I had him make me one with his even though I do not (yet) own a Mark VII.
