Looking for feedback on wood hardness chart
judaspre1982
Post by judaspre1982 »
beeg
Post by beeg »
[quote="JPG40504"]Do you know where I can get a magnifying glass? - At least it all fits!]
Just increase the size to 200%, then ya might be able to read it.
mikelst
Post by mikelst »
As I understand it you are asking for feedback on your chart and its usability.
With that as my goal...
I love the idea and it is obvious a lot of thought and effort went into the chart. There is a HUGE amount of great data here but...
My old eyes cant read it. It would be a much better effort for me (I know you made it for you not me:D) if it were in a larger font even if it ended up spread over a couple of pages. Or the front and back of one page that could then be laminated and hung on the wall above or even attached to the tool where I expected to make the most use of it.
Just my thoughts, you did ask:o
Mike......... Rowlett, Texas, near Dallas
86 MK V 500/520. 59 MK 5 Greenie Shorty. SS Jointer, SS Planer,
SS Bandsaw, SS Lathe duplicator, SS Belt Sander,SS Molder & Shaper,
SS Tenon master jig, SS Mortising kit, SS 2 1/4' Drum Sanders, Ringmaster, DC3300....
mikelst wrote:As I understand it you are asking for feedback on your chart and its usability.
Print it out greater than 100% size.
gpmark
Thanks for the input - here's the second part
Post by gpmark »
Still a work in progress so I will take your ideas and continue. It's now cleaned up and just a tad larger.
The second half is specifically for the ProPlanner upgrade is a speed/feed chart.
You can find the pdf here => http://beasleymhb.home.comcast.net/~beasleymhb/wood hardness and speed_feed.pdf
PS - Understand this is meant to be a quick reference only. Also I removed th s off of http so you shouldn't see the security certificate error.
After bypassing my security (computer claimed the site had a certificate error) I was able to view the site.
Lot of work here and that is to be admired!:) It is a large compilation and gives a good general idea of hardness of many species.
However, given the numbers, I was unable to tell if hardness is expressed in pounds/sq inch or other. Also, I would want to know if the chart addresses wood of what moisture content, is it speaking of compression hardness, shearing hardness, and is this table a combination of the above.
Does the table address hardness perpendicular to grain or other. Most tools cut into wood at a shearing angle. It's pretty hard to cut perpendicular to the grain. I believe most woodworkers don't really care about how many pounds of pressure or strike will crush wood. I think they just care about is one species generally harder than another.
If all one wants a table of how easily a ball pien hammer will leave a dent in a dried wood board, then we don't need a table with pounds - all we need is the colors.
If we desire more precise information, then Chapter 5 (Mechanical Properties of Wood) in the "Wood Handbook" will give those precise numbers. http://www.fpl.fs.fed.us/documnts/fplgtr/fplgtr190/chapter_05.pdf
judaspre1982
mikelst
Post by mikelst »
JPG40504 wrote:Print it out greater than 100% size.
Then id does not fit on a 'page' or single sheet of paper so formatting is lost.
If it were available as a spread sheet self formatting and alignment would be possible.
Try these!
[ATTACH]14510[/ATTACH] Speed chart added after initial post!
[ATTACH]14504[/ATTACH]
[ATTACH]14505[/ATTACH]
[ATTACH]14506[/ATTACH]
wood hardness chart scn ul.jpg (329.88 KiB) Viewed 2534 times
wood hardness chart scn cl.jpg (318.58 KiB) Viewed 2537 times
wood hardness speed chart scn ll.jpg (326.96 KiB) Viewed 2537 times
JPG40504 wrote:Try these!
And these:
[ATTACH]14507[/ATTACH]
[ATTACH]14508[/ATTACH]
[ATTACH]14509[/ATTACH]
Each section is a jpg file. Right click and copy!
wood hardness chart scn ur.jpg (316.9 KiB) Viewed 2524 times
wood hardness chart scn cr.jpg (334.97 KiB) Viewed 2523 times
wood hardness chart scn lr.jpg (309.37 KiB) Viewed 2520 times
