With the added extension table miter slot mounted to a 500 extension table, you could make it now, and use it later after the 'upgrade' with no need to modify the 520 stuff.aloibl wrote:Dusty, thanks for the step-by-step. I purchased a couple of Shopsmith miter bars to make my own sled for 500 series top. (Can't use them until after Christmas!!) I need something to help me with my crosscuts on my little table until I get a chance to upgrade to the 520. Then I will be able to make a bigger cross-cut sled for the bigger table using the same miter bars.
Crosscut sled position indicators
dusty wrote: [ATTACH]14823[/ATTACH]
My own custom square.
[ATTACH]14824[/ATTACH]
That a 1 7 12 block????
Well there are 1 2 3 blocks, 2 3 4 blocks 3 4 5 blocks...dusty wrote:Sorry but I do not understand the question.
Item 515494 is the t-track that was previously suggested, though there are other t-track item numbers out there.dusty wrote:No that is not exactly how I did that. I had forgotten until you asked. I installed a Shopsmith miter track on one of my extension tables to facilitate the second miter bar.
When installed, the miter tracks are 22" apart. I'll look somemore for photos. I cannot imagine that I did not take pictures.
Hopefully, these will give you an idea of what I did.
[ATTACH]14828[/ATTACH] [ATTACH]14829[/ATTACH]
damagi AT gmail DOT com
