What dimensions of tables do you all use? I was envisioning a 8'long by 30" or 36" wide. Height a question but more for the user to determine I'm guessing.
What type of materials to male the top? Would 2x4's on end be good/inexpensive with a 1" top? MDF or just the pine.
Bench Dawg Tables
Here is mine in a couple shots.
Cheaply made but dead flat. 3/4 ply top. Ribbed torsion box construction. 3/4 pipe clamp holes spaced throughout and able to pass a pipe all the way through.
48x29x33 1/2h. Holes for dawgs spaced every 2.5 inches. Dawgs are 1/2 inch hardwood. Holds up to my obvious planing needs.
[ATTACH]15732[/ATTACH]
[ATTACH]15729[/ATTACH]
[ATTACH]15730[/ATTACH]
[ATTACH]15731[/ATTACH]
Some tools are set for 33 1/2 high. Thats the tablesaw, router table (doubles as TS outfeed and this bench doubles as TS support for ripping plywood.
- top.JPG (53.78 KiB) Viewed 1702 times
- clamp.JPG (52.32 KiB) Viewed 1702 times
- under bench.JPG (44.05 KiB) Viewed 1701 times
- side.JPG (48.8 KiB) Viewed 1703 times
I have attached the plans for the one I use. I chose this one because of my very small shop and I've put on locking wheels so I can get it out of the way. My shop is small enough that I can only use either my Shopsmith or my workbench at one time, not both. Glad for locking wheels.
Abraham Lincoln
Abraham Lincoln
- trainguytom
I guess the key here is not whether square ones or round ones are better, just remember not to try to put a square peg into a round hole.... which reminds me of when a school kid replied to a teachers request for the formula for the area of a circle by answering "pi R squared", to which the not-too-bright kid in the next desk whispered " wow, at my house, pie are round.
I know, I know, very old cheesy story...just a little too much time on my hands tonight.
My dad's 1951 10er, 2 more 10er's, same vintage, a Goldie MK5, a 510 shortie with 34inch tubes, bandsaw, jointer, jigsaw, belt sander, a ton of small SS goodies and still looking...you just can't have enough Shopsmith stuff
trainguytom wrote:I guess the key here is not whether square ones or round ones are better, just remember not to try to put a square peg into a round hole.... which reminds me of when a school kid replied to a teachers request for the formula for the area of a circle by answering "pi R squared", to which the not-too-bright kid in the next desk whispered " wow, at my house, pie are round.
At least you did not have to endure the ancient chairman of the electrical engineering dept. tell it repetitively for 4 years all the while thinking how clever it was!;):eek:
He did 'teach' more than one class/subject/level during those 4 years!:Dnuhobby wrote:Red, was this repitition you heard anything like Bill Cosby's "I took 4 years of Latin I " ?
I took latin 2 yrs - still greek to me!:D
artfuldodger
What about T-slot tracks for hold down clamps? Some people buy a special router bit that cuts a t-slot into your top so that you have a t-slot made of wood. I don't know how strong that would be. I think you can glue the metal ones in a slot. Rockler and Inca make versions. I'm sure homemade ones are used also. Here is a link to another company. I like the track that takes just a regulat 3/8" bolt.
http://www.ttrackusa.com/track_%20systems.htm
