Chad
STUMPED? Q&A's from "Shopsmith Bandsaw Maintenance: Greasing the Upper Wheel" & Removing Lower Wheel
Post by Chad »
Watch it here: https://www.youtube.com/watch?v=XJ4Tzn0 ... =50&t=215s
In the last video, we covered the greasing of the upper wheel of the Shopsmith bandsaw, which in my experience is among the most easily forgotten maintenance of the bandsaw. In this follow-up, we'll answer some of the questions about that process and show how to remove the lower wheel and bearing assembly. Here's that previous video: https://youtu.be/H1YPHGeYYC8
0:00 - Intro
0:26 - What about the bottom wheel bearing?
0:40 - Welcome new subscribers!
0:55 - No towels for you!
1:14 - Danger in using degreaser?
2:20 - You aren't alone if you've never greased the upper wheel bearings!
3:10 - Where's "Shaft"?
3:25 - What about replacing the bandsaw tires?
5:10 - Magnetic base LED sewing machine lights?
6:15 - Lubricate the blade guides?
7:14 - Link to needle bearings?
7:40 - Prepping for removal of the lower wheel & bearing
8:37 - Remove bearing retainer with 1/2" open-end wrench
9:50 - Tapping on the shaft with a rawhide mallet
10:14 - Examining the bearing assembly (water pump bearing assembly)
12:28 - A case for owning a rawhide mallet
LINKS to products that were used and discussed in this video (in no particular order):
- Scott's favorite rawhide mallet: https://amzn.to/3g3RhJR Garland makes several sizes but the No. 4 has the best size for weight ratio for
woodworking.
- Here's the needle bearing. Remember, you'll need two: https://amzn.to/33y6IoG
- Scott's favorite double-ended wrench: https://amzn.to/3gYAMgM
- Here's an Amazon link to the SpecTape that I use for temporary bonds: https://amzn.to/3jk023k
- Here's an Amazon link to the FastCap SpeedTape that I use for permanent bonds: https://amzn.to/3jhCiN6
The jury is out on which of these replacement bandsaw tires I will ultimately prefer, but if you need to get going on replacing your bandsaw tires, I will be installing and testing the orange tires from Shopsmith.com and the "Blue Max" tires from Amazon: https://amzn.to/3o2LPcM
Follow on Instagram @MyGrowthRings
I also blog at http://www.tool-hunter.com and http://shopsmith-tool-hunter.blogspot...
DISCLAIMER:
A few viewers have requested I provide affiliate links to help them find the products I use and as a way of supporting the channel through commission. If you purchase a product or service with the links I provide, there is no additional charge to you. As an Amazon Associate and an eBay affiliate, I may earn a commission from qualifying purchases. I always recommend shopping around for a better price. Thank you for supporting My Growth Rings!
#hopsmithBandsaw #Shopsmith #ShopsmithBandsawMaintanance
Chad
Upgrading the Shopsmith Quill Lever to a Quick-Release Multi-Position Lever Handle. Is It Worth it?
Post by Chad »
Watch it here: https://www.youtube.com/watch?v=Ojycngl ... B&index=51
Scott's Shopsmith Mark V's quill handle was ruined recently when the headstock took a dive off his Workmate, so after some encouragement in a video comment from John Rice, Scott took the opportunity to upgrade to Geoffrey Baker's "Quick Release Quill Feed Handle Kit". Geoffrey's been showing this kit on his Youtube channel and on the Shopsmith Owners Group on Facebook and in the Shopsmith Forums, and Scott didn't fully understand what was included in the $125 price, so he reached out to Geoffrey for answers. What Scott learned was the kit isn't just your choice of whether the single handle or the three-handle configuration as it first appeared, but rather you get:
- One 12" long lever with quick release hub,
- One 8" three-handle with quick release hub,
- Two 19- spline hub adapters that stay attached to the headstock.
Once Scott learned what was included he decided that it was worth a closer look. Don't forget to leave your questions, comments, and Cheapshots in the video comments and we'll address them during our mid-week video.
0:00 - Intro
1:26 - A few quill handle options
4:00 - Geoffrey Baker's "Quick Release Quill Feed Handle Kit"
5:17 - What's included in the kit?
6:11 - How the quick-release hub works
7:07 - Yep, Scott boogered it!
8:55 - How much further does it stick-out? (Part 1)
9:16 - Wiggle & jiggle®
10:13 - How much further does it stick-out? (Part 2)
- Geoffrey Baker's "Quick Release Quill Feed Handle Kit" available through him via eBay http://ebay.us/CNEwKz
- Shopsmith's Shopsmith 10-Position Quick Index Quill Feed Handle Upgrade sold by Shopsmith via Amazon: https://amzn.to/3mPpOxT
- Misc Shopsmith quill handle listings on eBay: http://ebay.us/d4w6Z6
Visit http://www.MyGrowthRings.com
Scott also blogs at http://www.tool-hunter.com and http://shopsmith-tool-hunter.blogspot...
Also, join him on the Shopsmith Owners Facebook Group at https://www.facebook.com/groups/68446...
DISCLAIMER:
A few viewers have requested Scott provide affiliate links to help them find the products he use and as a way of supporting the channel through commission. If you purchase a product or service with the links Scott provide, there is no additional charge to you. As an Amazon Associate and an eBay affiliate, Scott may earn a commission from qualifying purchases. Scott always recommend shopping around for a better price. Thank you for supporting My Growth Rings!
#Shopsmith #ShopsmithMarkV #ShopsmithQuillLever
thedovetailjoint
Re: Scott's My Growth Rings youtube channel & website
Post by thedovetailjoint »
I’m curious what others who own this quill handle kit think of it when not drilling. I’m planning on leaving the single handle on, but leaving it on the back of the headstock. Hey, and what happened to “Sup Chad”? Scott
bainin
Post by bainin »
I like the 10 position RE magnet handle from SS over the original handle. With 2 hubs, moving the handle out of the way from front to back of headstock is great and fast.
This aftermarket one just looks too big for what I do.
thedovetailjoint wrote: Mon Dec 07, 2020 8:15 am I’m curious what others who own this quill handle kit think of it when not drilling. I’m planning on leaving the single handle on, but leaving it on the back of the headstock. Hey, and what happened to “Sup Chad”? Scott
posting.php?mode=edit&f=10&p=274305
You might be interested in a couple of pix towards the end of the first 'page'.
LoL I searched vainly for forum member "mygrowthrings'.
I PM'd Chad to forward it to thee.
Chad
Post by Chad »
JPG wrote: Mon Dec 07, 2020 6:11 pm
My growth Rings is thedovetailjoint
JPG wrote: I PM'd Chad to forward it to thee.
I did indeed forward it to Scott a.k.a thedovetailjoint
Chad Nevels
    1963 Shopsmith Mark V "Goldie" 1-1/8 hp Serial # 379185
    1980 Shopsmith Mark V 500
    1994 Shopsmith Mark V 510
    1994 OKUMA LB15 II OSP7000
    2017 OKUMA LB3000 EXII SPACE TURN MY OSP P300LA
Chad
Scrapwood Reindeer
Post by Chad »
Since Scott has done so many great videos on the Shopsmith bandsaw; Nick Engler posted a great bandsaw project video earlier today. It's also posted on Nick Engler's Workshop Companion youtube channel & website thread, here on the forum, viewtopic.php?f=7&t=23891. I hope Scott doesn't mind if I post this on his thread as well. It's a quick and easy project. Just in time for the holidays. Check it out!
Watch it here: https://www.youtube.com/watch?v=W335wRy ... =11&t=123s
Get the patterns for these reindeer sculptures from our store at:
https://workshopcompanion.selz.com/item ... USYPRRQ4uE
Nick shows how to make a deer with just a few quick cuts on a band saw. It’s a handy technique called “compound cutting” and it can be used to make all sorts of three-dimensional shapes. These particular reindeer are sized so you can cut them from scraps of 2x4s. Or, glue up blocks from different species of scrapwood.
If you enjoy this video, check out our Workshop Companion Channel: https://www.youtube.com/channel/UCk480B ... hMfkBjhDpQ
And if you want clear, concise information on any woodworking topic, visit our Workshop Companion web site: http://workshopcompanion.com/
Chad Nevels
Chad
Post by Chad »
Ed in Tampa wrote: Tue Dec 08, 2020 10:57 am I am 73 I have been work working for at least 63 years I never miss an episode of Nick's Englers or Scott's growth rings.
If you miss these you are missing a wealth of information that takes years of experience to duplicate.
I followed Nick from the days of the first Hands On magazine, until today. The early Hands on magazines were handed out at Shopsmith demo's, collected a complete set that was a lot of Demo,s 🥴
Chad Nevels
thedovetailjoint
Re: Scrapwood Reindeer
Chad wrote: Mon Dec 07, 2020 11:01 pm Since Scott has done so many great videos on the Shopsmith bandsaw; Nick Engler posted a great bandsaw project video earlier today. It's also posted on Nick Engler's Workshop Companion youtube channel & website thread, here on the forum, viewtopic.php?f=7&t=23891. I hope Scott doesn't mind if I post this on his thread as well.
Chad, Nick is always welcome. All I want to know is, why is his bandsaw so high? Scott
Chad
Post by Chad »
thedovetailjoint wrote: Tue Dec 08, 2020 2:38 pm
Great question. I wondered that myself. Still can't come up with a plausible answer.
Chad Nevels
