Re: Scrapwood Reindeer
Chad wrote: Tue Dec 08, 2020 5:51 pm
thedovetailjoint wrote: Tue Dec 08, 2020 2:38 pm
All I want to know is, why is his bandsaw so high? Scott
Great question. I wondered that myself. Still can't come up with a plausible answer.
It ain't high. Nick is short? :D :confused:
Because that is the way he likes it? :D
thedovetailjoint
Post by thedovetailjoint »
jsburger wrote: Tue Dec 08, 2020 6:23 pm Because that is the way he likes it? :D
I've heard crazier things.
Chad
STUMPED? Q&A's from "Upgrading the Shopsmith Quill Lever to a Quick-Release Multi-Position Lever"
Post by Chad »
Watch it here: https://www.youtube.com/watch?v=ChcLrd4 ... B&index=52
In this episode of STUMPED? Q&A we take a look back at the Questions, Comments, and Cheap-Shots that came from this past weekend's video titled "Upgrading the Shopsmith Quill Lever to a Quick-Release Multi-Position Lever Handle. Is It Worth it?" Watch it here: https://youtu.be/OjycnglIlBM
Geoffrey's been showing this kit on his Youtube channel and on the Shopsmith Owners Group on Facebook and in the Shopsmith Forums, and I didn't fully understand what was included in the $125 (Postage included) price, so I reached out to Geoffrey for answers. What I learned was the kit isn't just your choice of wither the single handle or the three-handle configuration as it first appeared, but rather you get:
- One 12" long lever with quick release hub,
- One 8" three-handle with quick release hub,
- Two 19- spline hub adapters that stay attached to the headstock.
LINKS to products that were used and discussed in this video (in no particular order):
- Geoffrey Baker's "Quick Release Quill Feed Handle Kit" available through him via eBay http://ebay.us/CNEwKz
- Shopsmith's Shopsmith 10-Position Quick Index Quill Feed Handle Upgrade sold by Shopsmith via Amazon: https://amzn.to/3mPpOxT
- Misc Shopsmith quill handle listings on eBay: http://ebay.us/d4w6Z6
Here's the link to Geoffrey's Youtube channel: https://www.youtube.com/channel/UCp7Q...
0:00 - Intro
0:30 - Geoffrey Baker chimes-in
1:12 - Comments about the stock Shopsmith quill handle
1:46 - Is the "Baker Lever" too long?
2:26 - Where's the link!
3:42 - Support for the Shopsmith 10-position lever
4:19 - You can service the hub
4:47 - Could the shafts be different sizes?
5:34 - Straighten the bent handle
5:54 - Chopping mortises and my final opinion
Visit http://www.MyGrowthRings.com
Follow on Instagram @MyGrowthRings
I also blog at http://www.tool-hunter.com and http://shopsmith-tool-hunter.blogspot...
Also, join me on the Shopsmith Owners Facebook Group at https://www.facebook.com/groups/68446...
DISCLAIMER:
A few viewers have requested I provide affiliate links to help them find the products I use and as a way of supporting the channel through commission. If you purchase a product or service with the links I provide, there is no additional charge to you. As an Amazon Associate and an eBay affiliate, I may earn a commission from qualifying purchases. I always recommend shopping around for a better price. Thank you for supporting My Growth Rings!
Sup Chad! (Even though Chad doesn't want the attention, or to be singled out)
#Shopsmith #ShopsmithMarkV #ShopsmithQuillLever
Chad
Hollow Chisel Mortising with a Shopsmith Mark V or Mark 7 or any Drill Press, for that matter!
Post by Chad »
Watch it here: https://www.youtube.com/watch?v=89TwGU8 ... B&index=53
This week’s a long one, but if you ever want to give hollow chisel mortising a try on your Shopsmith you are going to need all this information. We will go over a couple modern changes in chisels and bits, how to sharpen and hone them, the set-up of the entire mortising kit and then we’ll put the stock quill handle to the test by trying to mortice with a 1/2” chisel, followed by doing the same with the aftermarket Geoffrey Baker levers.
Don't forget to leave your questions, comments, and Cheap-shots below and we'll address them during our mid-week video.
0:00 - Intro
1:00 - Changes in modern chisels and bits
3:55 - Sharpening and honing the mortising chisels
8:15 - How I store my chisels and bits
8:43 - Set-up and support of the table
11:18 - Hold-down
13:33 - Setting-up the chisel holder
19:20 - Actual mortising!
21:17 - How I mortise today and important final thoughts
- Here’s an inexpensive set of cone=shaped diamond stones for the inside of the hollow chisels: https://amzn.to/2LnCoGT
- Here’s the two-grit diamond stone for removing the burr and all-around sharpening: https://amzn.to/37hBvIF
- Here's the dry lube I used inside the chisel and on the flutes of the bit: https://amzn.to/3mdSqQA Works on tabletops and on your way tubes too.
- Here's the mortising package from Shopsmith: https://www.shopsmith.com/ownersite/c...
- Here's the Shopsmith mortising kit on eBay: http://ebay.us/aKfe1P
DISCLAIMER:
#Shopsmith #ShopsmithMarkV #HollowChiselMortising
Chad
STUMPED? Q&A's from "Hollow Chisel Mortising with a Shopsmith Mark V", Why I HATE some Chisel & Bits
Post by Chad »
Watch it here: https://www.youtube.com/watch?v=n5OLd5_ ... =54&t=921s
On this episode of STUMPED? I'll answer the questions and respond to the comments from this weekend's video on mortising on the Shopsmith Mark V with the SS Hollow Chisel Mortising Kit.
0:00 - Intro
0:40 - You must sharpen the bits!
1:20 - Does the 5/8" leave come with the kit and can you demo the old SS Chisel & Bit?
2:41 - How about a cheater bar?
3:08 - Use a 2X4 to prevent table defection
3:41 - The Ol' Dime Trick
4:12 - How about mortising horizontally?
5:29 - Yes, the table doesn't have to slip!
5:41 - No, you aren't a weakling!
6:00 - Use two stock quill handles
6:15 - Can I recommend an aftermarket chisel and bit set?
9:34 - You'll find links in the video's "Show More" drop-down
10:39 - Is it crazy to buy the Shopsmith Universal Tool Rest?
11:40 - Is mortising on a Shopsmith too complicated?
11:52 - Mortising with an old Shopsmith Chisel and Bit
12:14 - Use a backer board
15:46 - Which way do you face the chip exhaust slot?
18:43 - Summery and final thoughts
- Here's a link to the handy magnetic base LED lights that washed-out the video! https://amzn.to/2GpseU7
- Here's the 9" long 5/32" hex wrench that I prefer as my EDC "Shospmtih Toolbox" and at roughly $5, it's a KILLER DEAL! : https://amzn.to/3nr64kJ
Here's Nick's new Workshop Companion Youtube channel: https://www.youtube.com/channel/UCk48...
A few viewers have requested I provide affiliate links to help them find the products I use and as a way of supporting the channel through commission. If you purchase a product or service with the links I provide, there is no additional charge to you. I always recommend shopping around for a better price. Thank you for supporting My Growth Rings!
Chad
Looking for a Deal on HSS Turning Tools? 2021 Lathe Turning & A Short Intermission...
Post by Chad »
Watch it here: https://www.youtube.com/watch?v=kiCI7Wb ... =55&t=544s
Due to work and family obligations, this is going to be the last new video for almost a month! Look for our regular twice-weekly schedule to return beginning Jan 17th.
In preparation for a couple lathe turning vides I thought I'd let you in on what I believe is a good step-up from the Buck Bros. chisels that most of us purchased from Shopsmith when we got our Shopsmith tools. Though I remain a devoted fan of Robert Sorby and Record tools I just can't ignore the value that two sets of HSS (High-Speed Steel) tools from PSI bring to the party.
Here are a few links to these tools, which are available on Amazon:
- Benjamin's Best (PSI Woodworking) 8pc HSS Lathe Chisel Set: https://amzn.to/3ar9MXO
- If you already have a standard set of HSS tools and are looking to step-up to tools like an Oval Skew and a Diamond Parting tool, check-out this 6 piece PSI set: https://amzn.to/34vQOeP If this set is sold out, here's a similar set from Savannah https://amzn.to/3p9ftxz
- My precious! This is the 1" Robert Sorby Skew that I love to use: https://amzn.to/3h6yazs
-Here's the 1 1/4" Robert Sorby Skew that I shared: https://amzn.to/3p8Jca5
- Here's an 8 piece Robert Sorby Turning Tool Set that seems to have inspired the PSI set: https://amzn.to/2WxBWbm
0:00 - Intro
0:19 - A Short Intermission
1:25 - Talking turning tools: Buck Bros.
4:00 - Harbor Freight "Cheap" Carbon Steel Set
5:00 - High-Speed Steel tools from Robert Sorby
6:49 - High-Speed Steel tools "Record Power"
7:57 - The "Hercules Tool No. 3" carbide tool from Hunter Tool Systems
9:16 - PSI Woodworking's "Benjamin's Best: 8pc HSS Lathe Chisel Set
14:05 - Harbor Freight's similar "Winsdor Design" 8pc HSS Lathe Chisel Set
I also blog at http://www.tool-hunter.com/shopsmith-...
#BenjaminsBest #RobertSorby #WinsdorDesign
Chad
Before Turning On Your Shopsmith Lathe, Watch This!
Post by Chad »
Watch it here: https://www.youtube.com/watch?v=w_SS67q ... B&index=56
We pick-up where we left off in December (Happy New Year!) with some must-do prep prior to using your Shopsmith tools for turning. Don't forget to post your Questions, Comments, and Cheapshots for the mid-week follow-up episode of "STUMPED?" and next week we'll cover some turning basics including scraping vs shearing.
Here's a link to our last video where we walked through the HSS lathe tools mentioned in this video: https://youtu.be/kiCI7WbG6ZA
Chad
STUMPED? Q&A's from "Before Turning On Your Shopsmith Lathe, Watch This!"
Post by Chad »
Watch it here: https://www.youtube.com/watch?v=2iQ9GiiwHo4&t=13s
In this episode of STUMPED? I'll answer the questions and respond to the comments from this weekend's video on safely setting-up your Shopsmith for lathe turning. If you missed that video, catch it here: https://youtu.be/w_SS67qincs​
This is that crazy turning video where the guy turns a collum with Shopsmith tools: https://youtu.be/rQbzEz0-7X0​ and his blog shows the finished product: http://timetofiddle.yolasite.com/turn...​ He is my hero.
0:00​ - Intro
0:40​ - A sincere thank you
1:05​ - Graham is amazed that he hasn't been hurt!
1:26​ - Bruce asked about my rusty tool rest post
2:07​ - Wayne is gaining confidence in his Shopsmith tools! Has the tailstock eccentric cup changed?
3:05​ - Chad wonders if I'm sacrificing safety for comfort?
3:51​ - Ed asks if it is possible that the Lift-Assist could cause problems?
4:45​ - Gary notes that the Shopsmith is a low lathe, compared to many
5:54​ - Scott has added setscrews to some of his old Shopsmiths
6:33​ - Jg disagrees with the purpose of the large setscrew under the tiebar
7:00​ - Why I never use an extension with a fence on the left side
7:40​ - This "tolerance" (play) is eliminated on the Mark VII and the Mark 7
8:50​ - James finds some of Shopsmith's instructions difficult to follow
10:39​ - Paul asks about the turning limits of the Shopsmith
13:30​ - Franken Berry disagrees and points out EVERY error made in that crazy video linked above
Visit http://www.MyGrowthRings.com​
I also blog at http://www.tool-hunter.com​ and http://shopsmith-tool-hunter.blogspot...​
I also blog at http://www.tool-hunter.com/shopsmith-...​
#Shopsmith​ #WoodTurning​ #WoodLathe
Chad
Spindle Turning on Shopsmith Mark V with Benjamin's Best & Harbor Freight's HSS Lathe Chisel Sets
Post by Chad »
Watch it here: https://www.youtube.com/watch?v=7bG-MIAiy8U&t=64s
We FINALLY get to play with the two HSS lathe tool sets that we purchased back in December. In this vid I dust off my old spindle turning skills and even show you how rusty I am! If you want to learn to turn be sure to check out some of the channels that focus on turning, including those posted in the comment section below. (My subscribers post the best comments!)
