Heath's Woodworking Projects
bffulgham
Post by bffulgham »
....and in its spare time, it can be a bean sorter :D
Neat concept and project. Thanks for sharing!
Bud F.
robinson46176
Post by robinson46176 »
heathicus wrote:I goofed a couple of times, but compensated as necessary. The scraps were the thickness of the panels as seen in the pic (I didn't measure, but no more than 1/4"), but half the width. So each was a glue-up of two pieces. I found a few pieces that seemed to be bookmatched pairs and used my favorites for the front and the platform.
Cool... :cool:
Those are not goofs, they are design adjustments... :D
a1gutterman
Post by a1gutterman »
I like it! What do the inside parts look like?
Tim
fiatben
I'm with Tim
Post by fiatben »
I'd love to see the plans or get an idea about the insides. What a neat idea!!
heathicus
Post by heathicus »
I didn't go by any plans. Just dragged out the cedar scraps and figured it out as I went along. It is really pretty simple. I'll draw something out in Sketchup when I get a chance.
Heath
Central Louisiana
heathicus
Post by heathicus »
Here's a quick and dirty SketchUp with one side hidde so you can see the inside. As I built it, I didn't measure anything - just drew it out to what looked about right.
[ATTACH]16587[/ATTACH]
One thing I need to go back and fix is to make the side of the platform a little taller. The dice do jump over those walls every now and then.
Heath
Central Louisiana
a1gutterman
Thanks Heath! That is a good idea. I am thinking Christmas gifts...
Tim
robinson46176
I find this especially interesting because back in my mad scientist years (seed corn research) we made a unit that was remarkably similar out of Plexiglas to clean small batches of experimental seed types. If you went about half-way between the top two baffles and made a 1 1/2" hole in the back (opposite the tray) for a shop vac connection and remove the tray (we ran it into a small cardboard box) you would have pretty much the same thing. The vac sucked out the light stuff like bee's wings and other chaff but let the heavier kernels fall on through. Air flow was adjusted by a piece that allowed adjusting the size of the lower opening.
Being Plexiglas it was kind of fun to watch work. I just called it a "seed cleaner". The technicians called it an "aspirator". :rolleyes: :)
bffulgham
Post by bffulgham »
robinson46176 wrote:I find this especially interesting because back in my mad scientist years (seed corn research) we made a unit that was remarkably similar out of Plexiglas to clean small batches of experimental seed types. If you went about half-way between the top two baffles and made a 1 1/2" hole in the back (opposite the tray) for a shop vac connection and remove the tray (we ran it into a small cardboard box) you would have pretty much the same thing. The vac sucked out the light stuff like bee's wings and other chaff but let the heavier kernels fall on through. Air flow was adjusted by a piece that allowed adjusting the size of the lower opening.
Several years ago Susan and I stopped by the St. Vrain mill in Cleveland, NM.
(Side note: We own the vast majority of the St. Vrain, NM town site in eastern NM) What we saw there influenced my guess as to the function of Heath's project.
Here's the Mill:
[ATTACH]16606[/ATTACH]
Here's the seed cleaner/aspirator:
[ATTACH]16607[/ATTACH]
Here's the top end of the equivalent of Heath's project:
[ATTACH]16609[/ATTACH]
There was some pretty amazing woodworking on a couple of the machines in the mill. I don't know the function of this device, but I am very impressed with it's cabinet:
[ATTACH]16608[/ATTACH]
Bud F.
Is this a 'virtual reality' test?:D
Hmmmmm 4 image limit???? When did that drop from 5????:confused:
