I BOX review of sorts (spoiler alert)
rjent
Re: I BOX review of sorts (spoiler alert)
Post by rjent »
dgreen810 wrote:algale
There was one in my box to. Never have figured out where it goes. It's in my junk box.
rejent: After reading your post on set-up using the quill, I have a comment, if you use this method, I suggest when you set up the I-Box to the miter initially, move the quill out slightly otherwise it can only be adjusted only one way when you re-install after it has been removed for some reason. You may need to adjust it the other way. I found this out the hard way.
Don G
Of course Don, that is exactly the way I do it as well. Pretty simple and quick. I leave the miter locked down in the same place all the time, advance the quill an inch or so, set the jig, then kiss the blade .... done! :)
My one observation, if I may pass it on, is to not over tighten the jaws closed. Just kiss them also. i find it easier to get a good first "set" on the jig.
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
algale wrote:Just went to set up my new iBox and this fell out of the fence. Anyone recognize it or where it goes?
See if it fits the threads on the adjuster, it might have been on them for shipping protection.
Mike907
Post by Mike907 »
Reible is correct, it was for shipping protection.
algale
Post by algale »
Mike907 wrote:Reible is correct, it was for shipping protection.
Mike & Ed, thanks. Seems reassuring.
algale
Re: still shipping incorrect hardware for incra ibox miter
Post by algale »
reible wrote:A little package arrived in yesterdays mail.
I wasn't expecting this but here it is, another solution to the issue....
Has anyone else gotten the t-bolt and this upgrade yet?
So, this is STILL a problem! They sent me a miter bar without the counter sinks but still supplied the screws with tapered heads. I will call customer service in the morning. They need to get this right!
Anybody who purchases an iBox is advised to remove the inserts in their miter bar and see what is going on. With the proper screws/countersink combo, the bar should have zero slop.
dgreen810
Post by dgreen810 »
Gotta make a comment: The little plastic item has a hole in it that is so sloppy, there is no way it would stay on the adjusting screw while making transport across the room, let alone across the country.
Don G
So, this is STILL a problem! They sent me a miter bar without the counter sinks but still supplied the screws with undercut heads. I will call customer service in the morning. They need to get this right!
???? AIUI the mitergauge 'head' is not thick enough for a full countersink head so the screws need to have a truncated tapered head. ***
Undercut not = truncated????
*** not the 'head', but the miter bar slop adjusters.
algale
Post by algale »
My mistake. Corrected original post. They supplied tapered heads without countersinking the bar.
Countersinking the bar was a workaround prior to discovering the screws s/b undercut.
algale
Post by algale »
JPG wrote:Countersinking the bar was a workaround prior to discovering the screws s/b undercut.
I don't want to have to countersink it myself. If I mess it up, then it is my mistake. I want them to send me the right hardware.
