Correct Greast to Lubricate Electric Motor Rear Bearing?
I am wondering if the questioner and the manufacturing reps are on the same page. The answer from GE is the one I would expect if the question was about an open frame design. I have been using bearings manufactured by Nachi in Japan and they have a unique design for the seals in their sealed bearings. The seals have a recess where the expanding grease can move to when the bearing gets warm and the grease returns to the interior of the bearing when it cools. If a bearing was to pull grease in to the interior of of the bearing it may very well be pulling in contaminated grease. I do not put any extra grease around sealed bearings as I don't think that it is necessary.
The only grease I use is a very small amount of white lithium grease on the outer shell to ease installation and minimize corrosion that would make the bearing difficult to remove from the recess at a later date.
XVB is the place to get bearings. They are first quality and less expensive than anyplace I've found, either directly in the Orange County area or on the internet. Don't waste time looking elsewhere. http://www.vxb.com/wa2crk wrote: I have been getting bearings from VXB Bearings on the internet for several years and have not had any problems. Bill
- trainguytom
The old Franklin 3/4 hp, I believe, has 2 different size bearings & I think that's true for the Emerson. I'd either get a caliper or find a friend with one & measure the bearings to find the size.
I get mine from Us Bearings & belts on ebay & have good prices & service & free shipping.
My dad's 1951 10er, 2 more 10er's, same vintage, a Goldie MK5, a 510 shortie with 34inch tubes, bandsaw, jointer, jigsaw, belt sander, a ton of small SS goodies and still looking...you just can't have enough Shopsmith stuff
trainguytom wrote:The old Franklin 3/4 hp, I believe, has 2 different size bearings & I think that's true for the Emerson. I'd either get a caliper or find a friend with one & measure the bearings to find the size.
ALWAYS!!!!!!!!!
OK!! I was working on an Emerson motor today and I believe I know why there is grease in the bearing cup. While trying to assemble the motor the spring washer that is behind the rear bearing does not stay in place when I tried to assemble the cover. A small amount of wheel bearing grease is necessary to hold that washer in place so the cover can be reinstalled.
Is that a mark V motor you are working on or one from one of the Power Stands? If it is a Mark V motor (1 1/8hp) does it have two bearings or just one bearing and a bushing in the rear?wa2crk wrote:OK!! I was working on an Emerson motor today and I believe I know why there is grease in the bearing cup. While trying to assemble the motor the spring washer that is behind the rear bearing does not stay in place when I tried to assemble the cover. A small amount of wheel bearing grease is necessary to hold that washer in place so the cover can be reinstalled.
[quote="wa2crk"]Dusty]
Thank you for the reply. I ask because I am about to do a bearing replacement on both of my motors. One is an Emerson and the other an AO Smith.
The Emerson Motor that was in my Crafters Station has a bushing in the back end. I was surprised to find that.
Just trying not to be surprised and/or unprepared when I take down the Mark V.
My power station emerson motor has a bushing in both ends. Yours had a bearing in the shaft end?dusty wrote:Is that a mark V motor you are working on or one from one of the Power Stands? If it is a Mark V motor (1 1/8hp) does it have two bearings or just one bearing and a bushing in the rear?
- fredsheldon
Dusty,dusty wrote:Thank you for the reply. I ask because I am about to do a bearing replacement on both of my motors. One is an Emerson and the other an AO Smith.
I know just what you need to keep you up and running while you have your motors down for maintenance
Fred Sheldon
The Woodlands, Tx
The Woodlands, Tx
