Greenie reassemble
mrhart
Post by mrhart »
Here is my 54 all spruced up and ready for business. Its not Micky-D but its way better than she started out (look up a couple posts) and runs pretty smooth for being 10 years older than me. It was a journey that was time well spent, as I now know alot more about the machine than just on and off. I still prefer to grip the outside of the speed dial instead of using the little handle, it seems like it should be slightly easier to turn the speed up than it is.
Thanks to all who guided me along. Could not have done it without your help here on the forum.
Next stop, the wood store.....
[ATTACH]18968[/ATTACH]
[ATTACH]18969[/ATTACH]
[ATTACH]18970[/ATTACH]
Oct 1 2012 214.jpg (106.63 KiB) Viewed 1245 times
Oct 1 2012 216.jpg (83.89 KiB) Viewed 1242 times
Oct 1 2012 217.jpg (108.33 KiB) Viewed 1245 times
R Hart
fjimp
Post by fjimp »
Easy on the eyes and ready to make woodworking a true pleasure for you. Congratulations. Jim
F. Jim Parks
Lakewood, Colorado:)
It looks great but needs some sawdust. Now it's time to start the overhaul on the scroll saw.
heathicus
Post by heathicus »
JPG40504 wrote:Originally tinnerman like clips were used to secure the logo. The clips fit over the 'posts' on the backside of the logo. They pushed onto the posts, the center portion opened up, but held the post very securely. MickyD initially used rubber grommets over the posts, but he had the ER with the 'hole' and a 10E logo with no retaining 'clip'.
I'm pretty sure it was the Mark V access hole cover he used the rubber grommets on, not the 10ER. But I can't recall if he drilled that access hole or if it was already there.
EDIT: here is the post: http://www.shopsmith.net/forums/showpos ... tcount=289
Heath
Central Louisiana
heathicus wrote:I'm pretty sure it was the Mark V access hole cover he used the rubber grommets on, not the 10ER. But I can't recall if he drilled that access hole or if it was already there.
EDIT: here is the post: https://forum.shopsmith.com/viewtopic.php?p=37554&postcount=289
He had a ("B" headstock) with a hole. He had a logo without a clip.
He initially used a rubber grommet over the post and slipped the grommet between the 'fangs'.
I know this since I swapped one with the clip for his without(I needed it for an "A" headstock).
His was a LOT shinier!:D
My saying 10E and 10ER was a 'senior' slip! Sorry! So much for perfectioin!:D
mrhart
Post by mrhart »
dusty wrote:It looks great but needs some sawdust. Now it's time to start the overhaul on the scroll saw.
Parts are ordered sir.
R Hart
mrhart
Post by mrhart »
Well, I pioneered the application of a new product for this issue. Velcro. Simple and seems to hold ok with the vibration ect. :)
R Hart
mrhart wrote:Well, I pioneered the application of a new product for this issue. Velcro. Simple and seems to hold ok with the vibration ect. :)
Since there is no access hole, gluing it on seems viable!
or just get a diy pp upgrade.;)
