Bit and Chisel mortising on a Shopsmith
Gene Howe
Post by Gene Howe »
Keakap....Please tell us (or at least, me) more.
I've been using the dado set.
keakap wrote:Don't forget the bridle joint. There's a band saw cutting sequence that is almost automatic, fast, accurate and requires no measuring or layout (!). {Haven't tried it on the table saw yet.}
Gene
wasatch
Post by wasatch »
How about a loose tenon using this: http://www.rockler.com/how-to/jessem-zi ... ut-joints/
You can make the tenons using the table saw to cut a long strip the correct width and thickness then a router table and roundover bit for the edges, then cut the strip into tenon length pieces.
Forget it? Heck, I had never even hear of it!
I Googled it, and it is indeed reputed to be a very strong joint that can look great in the right application. So I hereby second the request for more info on the quick-and-easy bandsaw technique! :cool:
BuckeyeDennis wrote:Forget it? Heck, I had never even hear of it!
Hint: It has nothing to do with horses!:D
TheBigE
Post by TheBigE »
Ever thought of using the router chuck in drillpress mode? You could use stops on fence. And you only have to square the corners when done. Shopsmith even has a package for this very setup. http://www.shopsmith.com/ownersite/cata ... tising.htm
Erich
1986 Mark V 500, SS Bandsaw, SS Belt Sander, Shaper Package, SS Molder, SS Oscillating Drum Sander, Excalibur EX-II scrollsaw, Central Machine 6 1/8" Jointer, Rigid 13" planer, Various routers and table.
"Remeber, you're unique. Just like everyone else."
TheBigE wrote:Ever thought of using the router chuck in drillpress mode? You could use stops on fence. And you only have to square the corners when done. Shopsmith even has a package for this very setup. http://www.shopsmith.com/ownersite/catalog/rm_slotmortising.htm
Erich
Yes, but had not considered the tenon master since it is a fairly recent acquisition. Thanks!
Snagged it!
Gene Howe wrote:Dennis,
I'd offer $150 and see where it goes from there. Wouldn't go over $175...Well, $200, but only if you really love it.:D
A very good Craigslist day today. First I called Shopsmith, and they do have all three sizes of router pin and the pin insert in stock -- for a total of $25. :) Shopsmith comes through again!
Meanwhile, the seller had dropped his asking price to $150 after a couple months with no takers. So I told him about the missing pins and insert, and offered him $125. He barely hesitated before accepting -- guess I should have tried offering $100. ]23607[/ATTACH]
[ATTACH]23608[/ATTACH]
Ed, the table is perfect, and the stand is indeed wobbly per your prediction. There's a few knobs and fasteners missing, but nothing that $10 and a visit to the local Ace Hardware won't fix. So it looks as if replacing the missing bottom rails on the stand is the only real work to be done.
Thanks for all the feedback, guys!
Craigslist photo 1.jpg (23.46 KiB) Viewed 4096 times
Craigslist photo 2.jpg (35.52 KiB) Viewed 4098 times
BuckeyeDennis wrote:A very good Craigslist day today. First I called Shopsmith, and they do have all three sizes of router pin and the pin insert in stock -- for a total of $25. :) Shopsmith comes through again!
Nice acquisition!:cool:
