Hey Dusty.
My post was about vertical not horizontal space.
Since I use an aftermarket table that does not use the rail assemblies and may also be a different thickness than the SS version, plus my Triton router might be taller than SS planned for, it might be that I have to raise mine vertically to get clearance from the way tubes in a fashion the SS table does not. I did cut my router table with a tight enough fit so that I had to notch out areas on one end to accommodate the protruding pieces on the side of the main table.
Sorry if I caused a huge confusion here.
Be well,
Ben
router table tight fit
Re: router table tight fit
Remounting extension table seems to help a bit. I believe this can make it work, but the tolerances are tight, but manageable.
Thanks everyone for the assistance.
What is the purpose in those square hubs anyway?
wdelliott wrote:Remounting extension table seems to help a bit. I believe this can make it work, but the tolerances are tight, but manageable.
My guess is that they are created early in the machining process for use as a reference during later machining processes.
