=============JPG wrote:If upgrading to a 510 be aware there are two versions.
I did not know that,,, , what defines one from the other ?
The od of the rails are the same for both versions.Hobbyman2 wrote:?=============JPG wrote:If upgrading to a 510 be aware there are two versions.
It just keeps getting more and more complicated.JPG wrote:If upgrading to a 510 be aware there are two versions.
Back up a couple of posts.Dansmith wrote:It just keeps getting more and more complicated.JPG wrote:If upgrading to a 510 be aware there are two versions.![]()
Please tell me about the 2 versions; I had no idea aobut this. Thanks.
Thanks. How did I miss that?JPG wrote:Back up a couple of posts.Dansmith wrote:It just keeps getting more and more complicated.JPG wrote:If upgrading to a 510 be aware there are two versions.![]()
Thinner rail walls?? Unless the OD is effected, I don't understand why this makes a difference. I know about all the discussions on incompatibilities and alignment problems but I cannot buy in without experiencing it.JPG wrote:The od of the rails are the same for both versions.Hobbyman2 wrote:?=============JPG wrote:If upgrading to a 510 be aware there are two versions.
The fences mount the same, but there are three different versions of the fence that vary only in how the fence body is attached to the front.
The tables are 'almost' the same/compatible. The almost is caused by the later(current) version having thinner rail tubes. A very small difference, but can cause alignment problems if one mixes old and current in a setup.
Other non-critical differences are:
Older version - The mounting of the rails is by screws into tapped holes in the table front/rear edge. The screws are accessed through holes in the outer side of the rails.
Current version - The mounting of the rails is by studs welded to the rails. The studs pass through clearance holes in the table front/back edge and a kep-nut secures them from under the table. The middle stud location is different from the older version mounting screw. The clearance holes require/allow minor adjusting of the rails to the table top surface(up/down).
So the distinguishing visual detail is the access holes on the outer face of the rails.
Probably a good way to go. I guess if I find a great deal on a table system, first, I may go that route. However, I have a feelingrobinson46176 wrote:...
Personally I would probably look for a complete 510. I've always loved mine.![]()
No.Hobbyman2 wrote:So would that make extension tubes different as well?
