Incra V120 with Shopsmith Safety Grip
Re: Incra V120 with Shopsmith Safety Grip
Have hope. This may be a temporarily issue. If I go to the Incra site and attempt to put any of the miter gauge parts on order, I get the same result. (not just for Shopsmith unique parts) At the same time, a part for the I-Box that are Shopsmith unique is currently on my invoice list. I ordered yesterday.
RFGuy
Post by RFGuy »
dusty wrote: Fri Dec 18, 2020 11:34 am Have hope. This may be a temporarily issue.
Dusty,
Well, the Incra engineer specifically told me to search for a used one on eBay, etc. because they stopped making them. Out of production is definitely more severe than telling a customer to wait a few months for a new batch to be produced. Their taking down the weblinks seem to confirm production has ended for good on this item from them. Difficult to have hope based on this, but I will try.
📶RF Guy
RFGuy wrote: Fri Dec 18, 2020 11:38 am
Dusty,
OKAY, I guess that makes it so. Maybe you should call to check on the Shopsmith miter bar. They just might have one or two laying around.
algale
Post by algale »
I feel fortunate I already have Shopsmith editions of the V120 and the Incra Miter 5000 sled and an iBox. Good equipment, all.
RFGuy
Post by RFGuy »
FYI...I got this response below from Shopsmith Customer Service, so it appears that Incra has abandoned this and possibly Shopsmith one day will make a suitable replacement. It might be a while though...
From Shopsmith CS:
"It won't be in this configuration. INCRA has discontinued their miter gauge and is completely out of stock. Our Engineer is working on finding a suitable replacement, but that process is likely to take quite a while. "
📶RF Guy
I will never need to buy one since I have four miter gauges now (two Incra and two SS) but I do hope for the benefit others that if Shopsmith does make one they will be wise enough to make it "fit" their miter track.
RFGuy
Post by RFGuy »
Does anyone know what is different between the standard Incra V120 and the Shopsmith version? I was able to place an order at Incra for the Shopsmith version of the miter bar and shows it is shipping. I won't know until I receive it whether it is the correct size or not. I tried asking Incra what was different between them but got limited information. Just wondering what other parts might be unique to the Shopsmith version. IF the only difference is the miter bar and they are still selling them then I could buy a standard Incra V120 and swap out the miter bar.
📶RF Guy
algale
Post by algale »
RFGuy wrote: Sat Dec 26, 2020 9:41 am Does anyone know what is different between the standard Incra V120 and the Shopsmith version? I was able to place an order at Incra for the Shopsmith version of the miter bar and shows it is shipping. I won't know until I receive it whether it is the correct size or not. I tried asking Incra what was different between them but got limited information. Just wondering what other parts might be unique to the Shopsmith version. IF the only difference is the miter bar and they are still selling them then I could buy a standard Incra V120 and swap out the miter bar.
I was going to say none, but that's wrong. Here's the Incra standard version. Image.
The Shopsmith edition (with the safety grip adapter) is seen here: Image.
The differences I see are the Incra version has a tall black grip/knob to tighten the gauge when between 1 degree detents. The Shopsmith edition replaces this with a low profile star knob that doesn't interfere with the use of the standard Shopsmith safety grip. The other big difference appears to be the fence. There are two vertical pieces on the Incra version and the the Shopsmith edition only has one vertical piece.
Shopsmith also sold an adapter kit that allowed the Shopsmith safety grip to be mounted to the v120. The adapter kit was (1) a machined block of aluminum that attached to the miter gauge fence and had a tapped hole to receive the safety grip post to be threaded into it and (2) a smaller block of aluminum that fit over the the cap screw that is the fulcrum for the angle selector/indicator and accepted a machine screw through the base of the Shopsmith safety grip heel. Both aluminum blocks can be seen in the linked photo.
There are pictures early in this thread that shows the aluminum adapter block and the knobs. The back plate on the Incra Miter gauge would need to be drilled, Taped andand countersunk for the two screws.
RFGuy
Post by RFGuy »
Thanks guys...I appreciate it. Based on your pics and info, I agree that it should be "doable" to try to make one assuming I can get the miter bar from Incra. I noticed the new design of the miter fence on the V120, but I don't know when they switched to this. Guessing they wanted a beefier fence for attaching fence extensions, etc. that Incra sells. This new addition on the V120 might make attaching the Shopsmith safety grip more difficult. Unfortunately, the tracking is showing 3-5 weeks for me to get the Shopsmith miter bars from Incra so it might be awhile before I can attempt a conversion. I'll probably wait and see if the miter bars are the right size before trying to buy a V120 to attempt it.
📶RF Guy
