Can I get a cracked table insert repaired?
gfr92y
Re: Can I get a cracked table insert repaired?
Post by gfr92y »
stew wrote: Wed Feb 23, 2022 8:23 pm Sorry Joe that was just sold and shipped out yesterday.
No worries. It was my own fault. I should have replied sooner.
Joe
gfr92y
Post by gfr92y »
rpd wrote: Sun Jan 30, 2022 1:39 pm To repair, I would try attaching an aluminum plate to the underside of the insert with JB Weld.
I did that to repair a broken speed changer and it has worked well.
viewtopic.php?p=233908#p233908
chapmanruss wrote: Sun Jan 30, 2022 2:02 pm As for repairing the cracked insert do remember that they are only supported from the ends so any repair must support the location of the repair. Fortunately for you it is only cracked on the one side.
Hobbyman2 wrote: Sun Jan 30, 2022 11:47 pm https://www.mastercool.com/product/alum-bond/
I have never used it .
So...
  • I decided to attempt a repair before buying a used or "new" one.
  • I decided against brazing because I felt there were too many opportunities for something to go wrong. (I can braze with my MAPP/Oxygen torch, but not weld.)
  • I decided against affixing a piece of aluminum with JB Weld because using a very crude test, the flexural yield strength of a 1/8" thick aluminum bar was less than that of a similarly shaped bar of JB SteelStick
  • I decided to reinforce the plate with JB SteelStik by first coarsely sanding and scarring the underside of the aluminum plate, wall off both sides of the side of the plate with the crack, and tightly pack the two canals with JB SteelStik.
The repaired plate fits perfectly in its seat.
Thank you, everyone. Sharing your experience and advice allowed me to implement a repair I am very confident in.
Thanks, again.
Joe
