Mark VII Idler Shaft Damage
Re: Mark VII Idler Shaft Damage
I have a bearing that goes into the end of the control sheave on a small metal block with two pins that connect to the control cam. The one that was in mine was really small and does not make contact with the inside of the control sheave is that normal?
I'm guessing that bearing should fit sung?
15mm will not fit the 5/8" idler shaft. The bearing marking will usually NOT specify the 5/8" id deviation.
kmilesone wrote: Sun Feb 25, 2024 3:37 pm I have a bearing that goes into the end of the control sheave on a small metal block with two pins that connect to the control cam. The one that was in mine was really small and does not make contact with the inside of the control sheave is that normal?
Snug and likely staked.
GerikBensing
- Silver Member
The control sheave bearing seems to have some wobble in it with the part that comes out the end. Is it normal? Bearing seems to spin fine besides that. Probably a non-issue since it’s held in place by the nylon speed controller part. I’ll check with Motion with the info provided to see what they can do for me. Thanks!
sorry, I have been researching bearing for a week now and gave the wrong part number here is the right one 6202-10-ZZ 6202-5/8-ZZ (5/8x35x11mm) C3 Premium Shielded Radial Ball Bearing 10 Pack $16.99 from amazon 2 Metal Shield ID: 5/8" OD: 35mm Width: 11mm.
I have 10 and only need three I'm willing to share if needed.
I am glad you did not purchase the incorrect one!
I think Gerick may have purchased some shaft material, and you have some bearings that he needs, maybe PM him and work out a trade?kmilesone wrote: Mon Feb 26, 2024 9:11 am I have 10 and only need three I'm willing to share if needed.
Mike -
Atlas 7B Metal Shaper
Here are a few pics of the first completed shaft for JPG.
- 20240303_160611.jpg (384.25 KiB) Viewed 5353 times
- 20240303_160913.jpg (223.44 KiB) Viewed 5353 times
Here's another one.
- 20240303_160642.jpg (286.32 KiB) Viewed 5352 times
... and an action shot, milling the keyseat.
- 20240303_141245.jpg (240.46 KiB) Viewed 5351 times
