Simple project advice
Re: Simple project advice
It looks good, especially with the painting. I agree with her...
- edflorence
Very good looking frame!
Idaho Panhandle
Idaho Panhandle
You might consider a clear finish. Something to protect the wood. It doesn't take much to leave smudges or stains on bare wood like that. Maybe a semi-gloss poly, shellac, or even a good coat of wax.
Ron--K6VPV
510, upgraded to 520, now PowerPro, bandsaw, jointer, belt sander, jointmatic, scroll saw, strip sander, pro planer, OPR, DC3300, and more.
kas20amc02
That’s a good looking picture frame. I doubt mine will be that precise.
Total rookie - advice welcome
Inherited Shop Smith 510
Sawstop cabinet saw with built in router table
Delta 1/3 HP combo belt/disc sander
10" folding Craftsman miter saw
Grizzly G0803Z 9" band saw
Bosch 2.25 HP router + Dewalt Trim Router
Dewalt orbital sander + Ryobi mouse sander
+1RonKlein wrote: Mon Jul 14, 2025 7:03 pm You might consider a clear finish. Something to protect the wood. It doesn't take much to leave smudges or stains on bare wood like that. Maybe a semi-gloss poly, shellac, or even a good coat of wax.
- Matanuska
1984 Mark V upgraded to 520 PowerPro. Shopsmith cast iron table bandsaw, jointer, belt sander, and 60's vintage 610 jigsaw SPT's. Makita 2040 15" planer, JessEm Mast-R-Lift II router table.
Thank you all for your input. I will try to convince her to put something on the wood to protect it
b
b
I actually like the flat look of the frame as-is and I think it complements the painting really well. IF you finish it, I hope you find a finish that keeps the same aesthetic. JMO. Of course, pine will naturally yellow with time so a true clear finish on it could protect it from this.bainin wrote: Thu Jul 17, 2025 4:23 pm Thank you all for your input. I will try to convince her to put something on the wood to protect it
b
RFGuy - I like it too . I will be trying to find something with minimum impact on current aesthetic.
b
b
If she likes the current aesthetic and as long as there is minimal chance of something spilling on the frame, why not leave it as-is for now? IF you change your mind in the future and/or the frame starts to yellow, you could always demount the picture and sand the frame to restore it and finish it at that time. I agree that most of the time, wood MUST be finished, but this is a case where I think the aesthetic may trump that common assumption. JMO.bainin wrote: Thu Jul 17, 2025 8:40 pm RFGuy - I like it too . I will be trying to find something with minimum impact on current aesthetic.
b
kas20amc02
I finished my poplar box. It was much better than my original and I built it faster. I learned from my mistakes and was much happier with the result. I am sure most on the forum could do better, but I made it with my own hands. Pictures...
- IMG_5465.jpg (253.6 KiB) Viewed 74822 times
