Bandsaw Insert
heathicus wrote:Mine is kind of beat up, but a scan is attached.
EDIT: Nevermind. I just remembered you said your table was aluminum. The image I attached is of the insert for the cast iron table. But I'm leaving the image attached in case somebody else ever needs it.
From his initial post, I thought he had a CI table.(no screws...)
FWIW, The alum table version od = 3 1/4 ", 1/8" thick
[ATTACH]9707[/ATTACH] [ATTACH]9708[/ATTACH]
[ATTACH]9709[/ATTACH]
band saw insert alum table top.jpg (96.3 KiB) Viewed 1807 times
band saw insert alum table bottom.jpg (105.87 KiB) Viewed 1806 times
band saw insert alum table clip.jpg (49.65 KiB) Viewed 1807 times
mgdesigns
Post by mgdesigns »
Thanks for those photos. That may be better to buy than make, but I have to try my hand at it first.
