Bandsaw Insert
Bandsaw Insert
I just acquired an older Mark V, and the bandsaw needs some work. The insert for table is non existent, and measures 2.5". I can make one of aluminum sheet stock, but does it need to be really tight fiiting so it won't wobble around when sawing? Do the originals have screws to keep them oriented? No screw holes are in the table.
Also - I have an extra old Greenie Table Saw table with fence, and thought it might make a great bandsaw table and rip fence. Has anyone done this? Will it fit up ok?
Thanks from the Newbie.
MG Designs
Custom Hand Engraving
And maker of Fine Kindling and great sawdust.
MG Designs
Hi,
I will let somebody else talk about Inserts.
For the Fence, just one idea was discussed on another forum which was highly entertaining:
http://www.ssug.org/index.php?option=co ... 74&limit=6
Have fun! Planning and imagining are as much fun as the real work sometimes.
Chris
foxtrapper
As for the fence, it makes big difference if we're talking the earlier iron table, or the later aluminum table.
As for the insert, the oem one uses spring clips that go through the hole and simply hold the insert by friction. No big deal to fabricate one, but the oem one is cheap enough to make it worth consideration. And if you're not going to make close quarter cuts on small stuff, just make that aluminum or wood insert with a center hole large enough for the saw blade regardless of orientation.
Is your table cast iron? The insert on my cast iron bandsaw table doesn't have any kind of screws or spring clips. There is a notch in the table that a protruding "key" from the insert fits into for alignment with the table. Otherwise, it's just sitting there with only gravity holding it in place.
Heath
Central Louisiana
Central Louisiana
foxtrapper wrote:As for the fence, it makes big difference if we're talking the earlier iron table, or the later aluminum table.
Is this also true for the older cast iron table?
Never Mind, Heath simultaneously answered that!
I just recent bought a pair of inserts for my iron table, circa 1980ish.
Before, I railed at the idea of paying the price so I just laid a piece of 1/8 Masonite over the entire table and added strips of wood under it to hold it tight on the table. Sorta framed in the table under the Masonite. I rarely use a fence or miter gauge, so that wasn't a problem.
Gene
Bandsaw Insert
I have been using the 2 1/2" Delta Zero Clearance Bandsaw Inserts from http://www.rockler.com/product.cfm?page ... ign=amazon
They have worked well for the original steel Bandsaw tables for me.
