Sawdust Session Playback
JPG40504 wrote:Waiting for blip.tv ......................................................................................................................................................
Are you still waiting?
If you can't get to the site then that is the problem to look for. Got any software that blocks sites installed?
reible wrote:Are you still waiting?
I am confused! I have been struggling to get flash player 10 installed for several weeks now.
I added adobe to downloadable sites to firefox, I removed version 9, I downloaded 10, installed it(twice) and got installation successful msg.
When I go to add/delete pgms, it says I have version 10 'plugin', with no size indicated????
Look at \.......\adobe and only reader,acrobat, photoshop folders. Where SHOULD flaSHPLAYER RESIDE?
Hi,
I think I recall hearing you are a Firefox user so I would then use the "about:plugins" to check to see if it is installed and what version....
Should look something like this...
[ATTACH]9863[/ATTACH]
edited to provide a better image
ScreenHunter_03 Jul. 30 10.37sc.jpg (168.23 KiB) Viewed 2175 times
OK it seems if you type : with a p after it you get :p.
without the extra spaces you need it to say "a b o u t : p l u g i n s"
SDSSmith
Post by SDSSmith »
reible wrote:OK it seems if you type : with a p after it you get :p.
How about "about: plugins"? Just need the space after the colon just like Mr. Jackson, English teacher, taught us.:D
Rob in San Diego
heathicus
Post by heathicus »
SDSSmith wrote:How about "about: plugins"? Just need the space after the colon just like Mr. Jackson, English teacher, taught us.:D
While it may be correct English punctuation, it doesn't have the desired result in Firefox. ;)
For it to work in Firefox, there should be no spaces.
Heath
Central Louisiana
Maybe this is your answer.
___________________(origional sentence removed)
EDIT ---- Thought this sounded familiar! Still don't know much about computers, BUT - Here is a thread where I asked for help for the same issue.
I am giving you the whole thread - After scanning the first 20 posts - the answer may be in the last 10 posts. https://forum.shopsmith.com/viewtopic.php?t=3356&highlight=videos
20 - 24 back!!!!!
Been off this thread, and do not understand the later posts(resolve that later), but went searching on my own!
In answer to a ?? I previously posted, Flashplayer resides in \WINDOWS\system32\Macromed\Flash
[ATTACH]9887[/ATTACH]
That sub-direc ooops folder is shown above after successfully getting version 10... to install.
I manually cleared that directory (after clicking on the install/uninstall .exe file and uninstalling)and went back to adobe and installed version 10
The initial attempt to play from sawdust session 24 displayed a 'install plugin' now prompt. I did that and it did its thing, and guess what IT NOW WORKS!!!!!
[ATTACH]9888[/ATTACH]
Apparently a memory used null value is 'normal'.
I believe all this confusion was caused by previous unsuccessful attempt yo install version 10. I be;ieve remnents of version 9 were clogging/confusing the installation.
FWIW there were version 9 remnants remaining in the .......flash folder after 'uninstalling' version 9. As mentioned above, I manually deleted them!
Thank You all for the responses and 'clues'.
BTW Chuck: Where did you find an uninstall thingie on adobe.com????
flash directory.jpg (67 KiB) Viewed 2127 times
abobe installed.jpg (38.87 KiB) Viewed 2129 times
Well I figgered out what y'all were doing etc.
[ATTACH]9891[/ATTACH]
Looks 'normal'! Albeit truncated for 'clarity'.
So somebody tell us just what a 'plugin' is. An independant program function that can be 'added' dynamically(after base program is defined in executable form(compiled/linked))???
flash plugins.jpg (34.65 KiB) Viewed 2122 times
JPG40504 wrote:...
I believe I used the CONTROL PANEL then the INSTALL/UNINSTALL icon. Just clicked and uninstalled.
