31 Piece Forstner Bit Set 'On The Cheap'
SDSSmith
Post by SDSSmith »
[ATTACH]10386[/ATTACH]
mickyd wrote:I'm VERY glad I was mistaken since I now have a way to use my forstner bits within their max speed design parameters. I was pretty bummed knowing I'd have to buy a PowerPro in order to use my bits. (I intentionally ignored the speed reducer approach.......PowerPro would be more fun)
Anyone aware of a table that shows the RPM's vs. pulley / speed setting value when the speed changer is being used?
For the Forstner bits, set the speed changer up in the low speed pulley arrangement and then dial the speed down as slow as it goes. Here is one chart:[ATTACH]10386[/ATTACH]
SpeedChart.pdf
(219.28 KiB) Downloaded 550 times
Rob in San Diego
My My How quickly we forget!!!!!:rolleyes:
[ATTACH]10384[/ATTACH]
10 er speed.pdf
(19.02 KiB) Downloaded 541 times
heathicus
Post by heathicus »
mickyd wrote:I thought the speed changer only varied the speed within each of the individual 3 pully ranges while maintain the original stock min-max speeds. :confused:
As my dad used to tell me... "Well, that's what you get for thinking!"
mickyd wrote:Can't find any info on the standard pulley configuration RPM's.
It's on page 8 of at least one version of the 10ER user manual. :cool::D
ERSpeedChart.pdf
(219.28 KiB) Downloaded 531 times
Heath
Central Louisiana
SDSSmith
Post by SDSSmith »
JPG40504 wrote:My My How quickly we forget!!!!!:rolleyes:
That's pretty, but I think it is missing some information. I will stick with the other speed charts posted for now. I can understand them.]
Rob in San Diego
mickyd
Post by mickyd »
I looked for 20 minutes for that correspondance before I posted and couldn't find it. I knew the answer was there. I thought it might have been on my home PC. :o
I forgot that I forgot. Thanks!
Sunny San Diego
mickyd
Post by mickyd »
SDSSmith wrote:That's pretty, but I think it is missing some information. I will stick with the other speed charts posted for now. I can understand them.]
That's actually jpg's prototype artwork intented to be used for an acid etched brass speed indicator to replace the one on an ER that has a speed changer on it.
What's missing?
Sunny San Diego
mickyd wrote:That's actually jpg's prototype artwork intented to be used for an acid etched brass speed indicator to replace the one on an ER that has a speed changer on it.
What's missing?
What operations are used for the speed setting! i.e. all that stuff in the earlier posts by Rob and Heath!
BTW ANYBODY have an 8 position speed control indicator? I be curious re the dimensions. Or is it like BigFoot(just a myth)?
mickyd wrote:I looked for 20 minutes for that correspondance before I posted and couldn't find it. I knew the answer was there. I thought it might have been on my home PC. :o
It is on the one SWMBO lost the power cord for!:D
heathicus
Post by heathicus »
JPG40504 wrote:BTW ANYBODY have an 8 position speed control indicator? I be curious re the dimensions. Or is it like BigFoot(just a myth)?
According to my mental recollections of long past conversations on the 10ER Yahoo group, there is no difference between the 8 position and 5 position speed changers other than the marks on the indicator.
Heath
Central Louisiana
wlhayesmfs
Post by wlhayesmfs »
I have had both, there is no difference in the 8 or 5 just the numbers on the label.
Bill :)
Broken Arrow OK
