bending veneer
Spray on solution for softening veneers.
I had to restore a birdseye maple top to a dresser once, and the veneer was VERY brittle. I searched on the internet, and found a veneer specialty site. They sold a spray solution that you squirt on the veneer, and man, it was like plastic after about 2 minutes!! If anyone wants the name, I'l go dig it up. It really worked, and I found a superior heat sensitive glue for veneering that was equally as good. jimsjinx
If you are a part time band leader, does that make you a semi-conductor? Where do all the "unguided" bombs go?
