[quote="algale"]I'm probably missing something but with respect to performing a bevel cross cut on a long work piece, why let the cut off be on the high side of the blade at all? Wouldn't it be advantageous to mount the extension table on the "up hill" side of the blade (minus the rip fence of course) and move the miter gauge (or cross cut sled) into the left hand (up hill) miter gauge slot? Then you can let the cut off drop harmlessly away from the blade and on to the floor. When performing a bevel cross cut using the miter gauge there is always going to be the issue of managing the weight of the work piece while making the cut]When anything is on the uphill side, you must concern yourself with its' management. To deal with this, I work to maintain the uphill pieces as small as possible. When they do get kicked back, and they will, it is inconsequential.
On larger pieces, I use the other Shopsmith (this one being set for bevels) to cut the material down so that the cuti=off is small (manageable).
There are some limitations to using the tilted table. Just make certain you think through the process and don't do it if it does not seem safe. If you are in doubt - it is not safe.
Bevel Sled for the Shopsmith
