Gallery of Restorations
Shoprite
Re: Gallery of Restorations
Post by Shoprite »
tks, now I know the problem I have is the upper chuck is immobile and I will have to figure out how to free it up.
Good luck with that attitude. Folks here do try to help. Educating the less knowledgeable becomes impossible unless a common language/terms is present. The initial steps require gaining that common language. Yes a somewhat painful experience. However, no pain, no gain.
BTW you are getting there re your last post.
Shoprite,
The videos RF Guy linked show the later Magna/Shopsmith Jig Saw but it works the same as the A-34 Jig Saw made for the Model 10's. The Upper Chuck Assembly should move freely out of the Spring Cylinder Assembly against the spring tension. They do get "froze" up in the Spring Cylinder Assembly which took the most work freeing up during the recent restoration I did. With the Spring Cylinder/Upper Chuck Assemblies removed from the upper arm you can start to dissemble it. Removing the lock nut, washer and leather pump seal will help in being able to get some penetrating oil into the area that is froze up. This can take some time to work it free. Also unscrewing to remove the Spring Guide part number 143-31 from the threaded shaft will allow removing the spring and gain even better access to the area that is froze up. Unscrewing the Spring Guide can be difficult if there is any corrosion since there is really nothing to grip it for turning it off the threaded shaft. Use care so as not to damage any parts as they can be difficult to find replacements.
If you need it the PDF below is the Owner's Guide for the early version of the A-34 Jig Saw. If yours doesn't look quite like the one pictured, it is the later version. Still not a problem as they both function the same and the difference is the Lower Frame Assembly, Drive Housing Cover and the number of screws to hold the cover on. The later Lower Frame Assembly has a partial belt cover built in.
Jigsaw Model A-34_134-1X.pdf
(1.67 MiB) Downloaded 623 times
RFGuy
Post by RFGuy »
chapmanruss wrote: Wed Oct 12, 2022 2:26 pm Shoprite,
Russ,
Thanks for pointing this out. I didn't mention there are different jigsaws that Magna and Shopsmith sold, I believe, so thanks for pointing this out and reminding me. Also, in at least one of the videos, Scott mentions that he is NOT using a Magna/Shopsmith jigsaw, but rather the Taiwanese clone/copy of one. He does this often in his videos...so anyone watching to compare against their own equipment needs to remember this, i.e. it might not match your model exactly because a ripoff company manufactured the one in this video. :(
📶RF Guy
It been a while since I watched those videos and I forgot Scott had used a clone Jig Saw.
For clarification the later version of the A-34 Jig Saw is shown below. The easy way to tell this later version from the early version is the partial belt cover.
_
Jig Saw V2.jpg (99.66 KiB) Viewed 15921 times
For reference the early version of the A-34 Jig Saw is shown below. There is no partial belt cover.
_
Jig Saw V1.jpg (71.11 KiB) Viewed 15921 times
As I said before there is very little difference between the two versions which are the Lower Frame Assembly, Drive Housing Cover and the number of screws to hold the cover on. I have both versions but prefer the later version for use. This is not just because it is a bit safer having the partial belt cover but is actually the difference between the construction of the Lower Frame Assembly. The Lower Frame Assembly in the early version is open throughout and saw dust can get into the gear box. I have found saw dust in the gear box of all 3 of the early version A-34 Jig Saw I have restored. The later version corrected this by closing the gear box off from the rest of the frame.
The biggest difference between the A-34 Jig Saw and the Magna/Shopsmith Model 610 Jig Saw made after the introduction of the Mark 5 is the A-34 uses the Model 10E or 10ER table while the Model 610 Jig Saw is a more complete unit only needing a power source.
The Model 610 Jig Saw is shown below for comparison. This Jig Saw has either the "Greenie", "Goldie" or gray paint scheme depending on when it was made. A "Greenie" painted one I restored is shown.
_
610 - 76158.jpg (83.59 KiB) Viewed 15917 times
jpdalton
Post by jpdalton »
More 10-E Accessories
I finally got back to painting in the garage this fall, so got a few more accessories completed for the 10-E I showed here back in July. The original owner of the machine apparently really liked to add the latest gadgets when they were developed - lucky for me…!
(“before” shot)
John Dalton
Massachusetts
1948 10E, S/N 5052 (restored)
jpdalton
Post by jpdalton »
chapmanruss wrote: Sun Mar 27, 2022 1:30 pm Something I have been looking at is recreating the label for the top of the compressor. Mine are a bit beat up and it will be better to remove the old label and replace it with a recreation to finish the restoration.
Russ - I recently topped off my restored Magna Sprayer compressor with a new recreation label. Pretty happy with the results. I have extra copies of this one if you’re interested.
John Dalton
Massachusetts
jpdalton
Post by jpdalton »
Magna-Line Dual SPT Stand
I’ve finally had some time to work l on this Magna-Line stand I picked up last year. Still have a long way to go, but it’s starting to come together…
The original Powr-Kraft branded motor that came with it still needs some work, so still missing from the last picture.
John Dalton
Massachusetts
Post by Mike »
looks like it should be on display in a Shopsmith museum. Very nice
I may be old but I’m slow
https://www.schmuckatellico.com/
https://scshiftknob.com
I have mentioned in a previous post here about needing to finish the restoration of my Model 10E S/N 1076 but have neglected to post it here. Some of you may recall seeing it in other threads. Below it is shown with Model 10E S/N 1077 both restored on their matching benches.
_
1076 and 1077.jpg (199.98 KiB) Viewed 18466 times
