It seems that both camps may be correct. The proper term for the things on eBay appears to be a "dimple die set". In which case, the ones for sale are the male portion of the set, and the corresponding female pieces are missing in action.
See the following links for some examples:
http://www.aetools.co.uk/product-spring ... ts-886.php
http://www.swagoffroad.com/SWAG-Dimple- ... _p_92.html
http://www.mittlerbros.com/index.php/mi ... 7AodcU0AVA
They are indeed used to form "chamfers" in sheet metal. One application of this is to prepare aircraft sheet metal for riveting. And I saw something very similar shown with snap-installation equipment.
To V, or not to V?
- BuckeyeDennis
Tack så mycket:Didcook wrote:These look quite similar and it says they’re used to countersink holes in metal.
http://www.garaget.org/forum/viewtopic.php?id=286199
- idcook
BuckeyeDennis wrote:It seems that both camps may be correct. The proper term for the things on eBay appears to be a "dimple die set". In which case, the ones for sale are the male portion of the set, and the corresponding female pieces are missing in action.
That’s what I felt when I discovered that other set. I could see that single item could be applicable to both applications.
idcook wrote:Ja. (I thunk)
jo vars:D............
