DIY DVR motor upgrade / replacement
CNC4FUN
Re: DIY DVR motor upgrade / replacement
Post by CNC4FUN »
I have access to CNC machines and was thinking to make a new pulley but I can't find right cutter for this pulley profile.
I can order custom made cutter but then we are talking about time and money and I just don't want to waste any of it.
Sent from my LG-H872 using Tapatalk
thunderbirdbat
Post by thunderbirdbat »
Does it need to be a timing/cogged belt like it is now? SS switched from the Gilmer drive cogged belt to the poly-v belt, is something like that possible for you to do?
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
lahola1
Post by lahola1 »
If you can't find the correct pulley I would think a machine shop or tool and die shop could TIG weld it and grind it down for you.
SS Mark VII(sn 405025), SSband saw, SS 4" jointer, Older SS Mark V w/DC treadmill motor,
Smithy SuperShop 720, Powerkraft RAS,Craftsman RAS, Ridgid TS2412 Table Saw,
Delta 12" planer
CNC4FUN
Post by CNC4FUN »
Waiting for pulleys to arrive tomorrow.
In the mean time I reassembled motor and power takeoff shaft.
It is running just fine. I ran it from 100RPM up to 3500 and it's purring like a cat.
I love it.
Overall motor replacement was not difficult at all.
CNC4FUN
Post by CNC4FUN »
Today I bored one pulley to 50mm and drilled two side holes to secure it onto the spindle shaft.
CNC4FUN
Post by CNC4FUN »
I will have to cut away side wall on a new pulley because it is impossible to install a belt.
There is no clearance on the top side of the bore and belt can't pass over the right bearing onto the pulley.
Notice a bottom half cutaway on picture but zero on the top of headstock.
Am I missing something here????
Do I see an eccentric sleeve(with the bottom cut out)?
CNC4FUN
Post by CNC4FUN »
Finally, it's assembled and running.
Now I have to figure out how to install controller on the headstock.
Look at that belt "clearance" at top.
