SDSSmith wrote:Good to hear, those screws are not very big and can be a pain to remove the remnants from the hole.
Yes they are, couldn't do it without cursing a few times...
Apparently it helps to use the screw's native tongue!:Dmarkap wrote:Yes they are, couldn't do it without cursing a few times...
And I just had to "reshape" the 'headstock' {headREST}leg, hoping to remedy the non-plumb accessory mount. Found a 2lb. hammer does a fine job of "reshaping", and even assisted somewhat in 'reshaping' my attitude about these misalignments for a few heated minutes.SDSSmith wrote:... check to see if the legs have become bent or distorted. If this is the cast then the legs will need to be "reshaped".
Did it acquire a nice hammered tone finish?:Dkeakap wrote:And I just had to "reshape" the 'headstock' leg, hoping to remedy the non-plumb accessory mount. Found a 2lb. hammer does a fine job of "reshaping", and even assisted somewhat in 'reshaping' my attitude about these misalignments for a few heated minutes.
Turns out, tho, that the leg adjustments not only didn't help the dragging caster problem, but had little, if any, effect on the mount. Turns out the accessory mount tubes in the headstock are just not square to the bench tubes. So the accessory mount tubes lean in toward the center one full degree +. (Meaning it is impossible on this machine to set up the Extension table to be used on either end interchangeably.)
File to: So What Else Is New Dept.
But the leg looks nicer...
Nope. Unfortunately I couldn't find my (3 lb.!) ball peen hammer. Dang-- I coulda had me a really good time with that thing!JPG40504 wrote:Did it acquire a nice hammered tone finish?:D
I agree. I mostly pounded on a "go-between" piece of 2x4x4 with slightly rounded edges or used a home-made clamp (I don't have any long clamps).JPG40504 wrote:I be curious how one 'malforms' an aluminum end casting(headstock rest end)??? I assume it occurs unintentionally!:rolleyes:
I would assume the same. (Problem there would be in figuring out how to intentionally un-malform an unintentional malformation, eh?)
But in this case, if that is indeed what happened, my first guess would be that the unit encountered less than ideal treatment during its trip across the Pacific many years ago. As of now I don't know if that malforming occurred, and am guessing as to why the sets of holes are not perpendicular (as I assume they should be.
Quite likely, however, the point could well be moot. I have just received a surprise from Headquarters, and I must say it is a welcome and comforting one. Sometimes I just love to be mistaken. Rather I should say I love to find out I was mistaken-- goes a long way to dispelling angst regarding misconceptions about how stuff should work (if it doesn't).
Seems that: referring to your fixed extension table that has it's own mounting base, this table cannot be moved from one end to the other without being re-aligned. You will want to align it for either the left or right end of your Mark V and use it there only. Again, it cannot be interchanged without needing to be re-aligned. Your owner's manual should also state this information.
You may imagine my relief, as long as I've been working on getting this stuff aligned, 520 upgrade, new tables, et cetera, none of which worked, I can now blissfully ignore what my owner's manual actually does say as well as Nick Engler's Sawdust Session 13#3, and move on with my new stuff, including the extension table (almost)perfectly aligned in the base mount "only".
FWIW I have found clamps and boards and leverage effective on ss legs. Hammer required for sharp bends only.
There was something about that question-- and it just hit me.JPG40504 wrote:I be curious how one 'malforms' an aluminum end casting(headstock rest end)??? ...
keakap wrote: . . .
By the way, in investigating the tipsy table trouble, I found the bench tube clamp or lock bars to be a bit loose, or at least not quite tight. Correcting this did actually change the posture of the extension table base, and took most of the hula out of moving the whole machine. A plus.
Sorry, I wasn't clear. The bench tube clamps as I called 'em are listed as "tube lock bar", and are used to clamp the bench tubes to the headrest.JPG40504 wrote:The spt tube clamps ...the spt mounting tube, ....
