Restoring my 55' Greenie
cllib
To Cut the Access hole to fit my hand
Post by cllib »
I planned to use jig saw. But the blade was too hard to turn.
So decided to use drill and jig saw.
My hand barely fit into the hole.
How to put the logo legs to the small holes?
The rubber grommets are to thin. :(
55 SS Mark V restoration work in process
cllib wrote:I planned to use jig saw. But the blade was too hard to turn.
Get a 'newer' one with the retaining 'spring'.;)
cllib
What kind of primer?
Post by cllib »
What kind of primer would you suggest?
Self etching primer for aluminum? and for sheet metal?
Is it spray on or brush on?
There is self etchin Rustoleum primer in local homedepot. Or do I buy from
Oreilly auto store?
Thanks.
billmayo
Post by billmayo »
I have had great success with the self-etching primer. Just allow a day or two to dry.
cllib
damaged base
Post by cllib »
How do I fix the base? Can I use JB-weld and washer ?
Thanks.
I would try JBWeld. I would apply it a bit thick and then mill it down so that the legs fit. After that is done, drill a hole for the bolt.
There is very little stress on that tie point so I do believe a good application of JBWeld will hold.
I agree with Dusty, but question how/why it got busted to begin with????:confused:
cllib
Post by cllib »
JPG40504 wrote:I agree with Dusty, but question how/why it got busted to begin with????:confused:
I guess the reason was when the SS was "pushed" across the street this hole
might get stressed some how. The driveway is not flat. :(
dusty wrote:"There is very little stress on that tie point so I do believe a good application of JBWeld will hold."
I am not sure there is little stress on this tie point. The bench tubes were very loose when I disassembled them.
eartigas
Post by eartigas »
Must be common since my two greenies came with the same problem. The carriage hits there and I believe there was a crew in that place that facilitated the cracking.
Carmel, NY
billmayo
Post by billmayo »
cllib wrote:How do I fix the base? Can I use JB-weld and washer ?
Thanks.
Not an uncommon problem. I have drilled and countersunk a 1/4" hole 1" on either side of the broken hole which did not create any additional problems later. Thjis appears to happen when unloading from a pickup truck or trailer and the end is dropped before setting it on the ground. Could happen when moving the Shopsmith and the leg was stopped by a raised surface. Insuring all the leg bolts are really tight when moving the Shopsmith helps prevent this problem.
I find JB Weld does not hold up well when there will be vibration, stress or torque on the area being patched.
