I did. But the width of most of the pieces that make up the drawers are wider than what the SS band saw can handle.newportcycle wrote:Bill,
Did you consider resawing your stock with the bandsaw and then planing to final dimension?
Today in my Grrage - Bedroom Furniture Build
- mountainbreeze
Bill
Mark V 520 50th Anniversary Edition, Planer, Jointer, Bandsaw
Bed
Bill, I thought about doing the set once I saw your version, but I made a few changes along the way, I made my set in cherry, the bed has 2 drawers on each side and the night tables have 3 drawers in each. The drawers are 1/2" Baltic birch(Russian plywood, and cannot put the finish on until spring just too cold. Am glad that I got the inspiration from you to do this project. Figure by the end of it I will have made 2 beds 3 dressers and 4 night tables.
Dan
Dan
Mark V 520,Mark V 510(2),Mark V 500(2) Dust Collector(2), Jointer(2), bandsaw(2), jigsaw, beltsander, biscuit joiner(2) Lathe Duplicator, RingMaster, Pro planer
- mountainbreeze
My project is also on hold waiting for warmer weather. I have a dresser, 2 nightstands, a footboard, and the bed rails yet to stain and topcoat. Shouldn't be too much longer.
What bed rail brackets did you use? Our bed is a king and I am still looking to find the most heavy-duty bracket available.
I would like to see a picture of the bed with drawers. It sounds like a nice addition.
Bill
Cherry Bed
I did not use the strips that they suggested (lats) I made a center post running from top to bottom attached to the headboard and footboard (hardware from lee valley 00s17.10) the board was 7/8 thick and 4 inches wide and had a large t shaped support running the same direction as the center support. Each of the posts and the center support have 1 1/4 glides so I can raise or lower the bed to the height of the floor for full contact at all points. Then I ran four pieces of plywood sectioned so that I could add the drawers like modular units and added the face fronts to the drawers. Yes I did have to raise the height of the rails. Hopefully you get the idea on this if not I will send you a picture of the under mattress shot, but it is a b**ch to lift it very heavy.
Dan
Dan
- photo 1.JPG (114.79 KiB) Viewed 3602 times
- photo 2.JPG (117.55 KiB) Viewed 3570 times
- photo 3.JPG (128.29 KiB) Viewed 3567 times
- photo 4.JPG (119.19 KiB) Viewed 3585 times
- mountainbreeze
Nice work Dan. I like the drawers. That's a nice addition. Once I'm finished with mine I may look into doing something similar as an add-on.
What I was asking about was the hardware you used to attach the two side rails to the head/footboard. Did you use the recommended hardware from Rockler? Can you comment on how well it works in terms of the bed frame being ridgid?
Thanks,
Bill
Thanks,
Bill
Bill
Bed
Yes I used the bed hardware from Rockler, at first I hard a hard time figuring out which part went where so I made a mock up with some scrap material and then I got it. Once I put them on the rails and put it all together and put the locking screw in place it was a very good connection. Very secure and solid, I was happy with the result. No shakes rattles or rolls.
- mountainbreeze
