First Post: Inherited Rusty Mark V. Now What?
Re: First Post: Inherited Rusty Mark V. Now What?
I doubt you will need to replace the spring. Lube it maybe.
To increase tension, advance the quill as in the video until the quill separates from the pinion gear. Then rotate the feed shaft further, then reinsert the quill.
For red pouch. Ditto on caulk forms or even for masonry mortar / tile grout. They sure look clean.
Next question. What is THIS? (See attachment)
It's a plastic sleeve with a spring sticking out the end.
- Shopsmith-IMG_1210[1].jpg (151.12 KiB) Viewed 3670 times
Greenie #317956. Jointer Model 620 #40077
That's the drive coupler for powering SPTs like the bandsaw or the planer.
ERLover
Spring side to the HS, it is the only way it will fit on the drive hubs.
ERLover wrote:Spring side to the HS, it is the only way it will fit on the drive hubs.
Assuming the hubs are properly mounted where they should be(they CAN be reversed).
ERLover
JPG wrote:ERLover wrote:Spring side to the HS, it is the only way it will fit on the drive hubs.
They can? I never checked but thought for safety they were different IDs. You guys eat and sleep em, just tell me its true. I dont have time tonight and wont be back to moms till tomorrow.
NO NO, I dont thinks so in hind sight, that is why the inner spline spacing are different on the coupler ends. One end splines on the coupler spring end are different spacing then the one end for the hub on the SPT.
ERLover
Coupler none spring end has 5 internal splines, spring end has 4.
I TOOK THE TIME, GOTCHA JPG, Oh does it feel GOOD
Shafts diam on SPTs is larger then the drive shafts on the Mark V HS, did not measure but tried to flip flop hubs, I would say a 1/16" diam difference.
I am a smilen
I am a smilen
ERLover
See the differences
http://www.shopsmith.com/ownersite/cata ... r_hubs.htm
Best wipe the smile off.
Headstock has all 5/8" shafts, some SPT have 1/2" shafts while others have 5/8". So a SPT hub with a 5/8" shaft will fit on the headstock and the ones for the headstock will fit the SPT's with 5/8" shaft so YES they can be put on wrong.
ERLover wrote:Coupler none spring end has 5 internal splines, spring end has 4.
I TOOK THE TIME, GOTCHA JPG, Oh does it feel GOODShafts diam on SPTs is larger then the drive shafts on the Mark V HS, did not measure but tried to flip flop hubs, I would say a 1/16" diam difference.
I am a smilen![]()
